Missing BSplineCurve in 0.21
drmacro
Post by drmacro »
The error is thrown when attempting to import BSplineCurve.
from FreeCAD.Part import BSplineCurve
ImportError: cannot import name 'BSplineCurve' from 'FreeCAD.Part' (unknown location)
Did it get moved or completely replaced or...
OS: Debian GNU/Linux 11 (bullseye) (XFCE/xfce)
Version: 0.21.0.32634 (Git)
Hash: 161e7aca989ce15ee3cbcbb1d4b3ff47812ac899
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
Chris_G
Re: Missing BSplineCurve in 0.21
Post by Chris_G »
I get same error.
But this works however :
from Part import BSplineCurve
drmacro
Post by drmacro »
I found that after I hit the send.
This an external app using FreeCAD.
    from FreeCAD.Part import makeCompound
Changing to this corrects the issue:
    import Part
    from Part import makeCompound
Apparently the code worked prior to 0.21
Syres
Post by Syres »
drmacro wrote: Wed Mar 29, 2023 5:40 pm Apparently the code worked prior to 0.21
I believe your original code worked until quite/very recently!!
It could not be related to some Python version change?
from FreeCAD.Part ....
Using point import is discouraged if I remember well, but I have to check and now I'm not near a computer.
Edit, a note at end of :
Package Relative Imports
in Python documentation could explain why in some cases it will not work if applicable. There are even reference for some PEP so maybe here there is the advice
Kind Regards
drmacro
Post by drmacro »
Syres wrote: Wed Mar 29, 2023 5:56 pm
Actually not my code. Debugging failure in another app where FC modules are being used.
