Error when attempting to use Polar Pattern Feature
Re: Error when attempting to use Polar Pattern Feature
@thomas-neemann
Lol. I just realied what you tried to do with sketch 2, nvm.
- thomas-neemann
For the sake of simplicity, I created a working sketch using draft (arch). you can do it in sketcher. here is the download for realthunder
https://github.com/realthunder/FreeCAD/releases
https://www.youtube.com/watch?v=7tWkwWt_Bao
@thomas-neemann
Thanks for that but how did you create the polar pattern without receiving an error? Ich schätze die Hilfe sehr
I see that realBird is a branch off of freecad. I have never used it before. Would it cause any conflicting issues with my current version?
- thomas-neemann
I'm not a part design professional, but apparently there is a problem here, that the freecad-master-version can only contain 1 part per body. there seems to be an error in skech002 because you can't extrude it
- Proj_SHALM.FCStd
- (53.06 KiB) Downloaded 10 times
- Annotation 2023-03-31 160941.jpg (25.23 KiB) Viewed 391 times
- thomas-neemann
why does sketch002 work in partdesign and not in part?
In the original file, the pocket is alone in a new body, not in the cylinder body.
So the PolarPattern is duplicating something in the void : "Shapes do not intersect the solid" (as there is no solid).
You need to do a POCKET in the same body as the revolution.
Or perhaps you should use Part wb.
You gave us an incomplete file, which leaves me guessing, that Part cannot handle a single point.thomas-neemann wrote: ↑Fri Mar 31, 2023 2:27 pm why does sketch002 work in partdesign and not in part?
- thomas-neemann
I wanted to reduce the problem to a small file. here is a complete file
Version: 0.20.2.29603 (Git) AppImage
* Curves 0.6.8
- thomas-neemann
