There is a point in the sketch that is not construction.......thomas-neemann wrote: ↑Fri Mar 31, 2023 2:27 pm why does sketch002 work in partdesign and not in part?
Error when attempting to use Polar Pattern Feature
Re: Error when attempting to use Polar Pattern Feature
- thomas-neemann
- papyblaise
there is a stupid point 6 which blocks the rotation (and the Pad)
What is this construction line forest for
- stupide point6.JPG (22.29 KiB) Viewed 431 times
- stupide point6.FCStd
- (14.51 KiB) Downloaded 4 times
- thomas-neemann
that was it. thanks. i am wondering because a new sketch with point can be extruded
edit
I made a mistake when testing. points in the sketcher are construction points. my switch has caused the opposite of what I thought. but it is also the case here that partdesign can extrude it
A point on its own will extrude to a line, a point in a sketch with a closed wire throws an error if it is not construction.
- 1621Point.FCStd
- (8.91 KiB) Downloaded 5 times
- thomas-neemann
Thanks for the info. but there seems to be a difference if it is extruded in part or partdesign
- papyblaise
yes because with PartDesign it tries to extrude 2 superimposed objects, which is strictly forbidden
but why this ton of construction lines
- thomas-neemann
thanks, but this is confusing to me
Greetings to the Community!
The gif shows the point that generates the error (as already highlighted in the previous interventions), if we try to create a solid the error will always be signaled because we will not have a closed polyline/wire, this also happens if the point is finds above a line of the sketch that generates the solid.
If instead we create a ruled surface then everything works in fact the point is extruded in line and the sketch as a ruled surface.
- Error 1624 and 1709.gif (231.61 KiB) Viewed 346 times
- Error 1624 and 1709.png (83.59 KiB) Viewed 346 times
- thomas-neemann
I understand that, but why does it work despite the point in partdesign?
