Hey
I want to make a item, retangular with rounded corners, thats no problem, then i want to make holes ofset from the edeg al the way round in eaqual apacing. Can i do that our do i have to construct them all
Bedst regards Ege Juul Nielsen
Hole Pattern
Re: Hole Pattern
Hi and welcome to the forum!
Please tell us a bit more: which workbench do you use (Part, PartDesign), and upload an example of what you try to do.
On first sight: what you want to do sounds like asking for trouble caused by the topological naming problem.
- thomas-neemann
Re: Hole Pattern
If you want, I can link you to a video here or via pm where it can be seen
Re: Hole Pattern
Attached is a fully parametric file achieving IMHO what you asked for.
The only changes you need to make are the dimensional constraints in Plate_Sketch, size of hole in Hole_Sketch, the thickness of the plate in Plate_Extrude>LengthForward and the Expression in Holes_PathArray > Count > where 100 is spacing in millimetres between hole centres inorder to calculate the number of holes. I'm sure you'll try and break it but give it a whirl.
Edit: trunc is a better function than round as it always goes towards zero.
trunc(Sketch002.Shape.Length / 100)
Version: 0.20.2.29690 (Git)
Branch: releases/FreeCAD-0-20
Hash: 05a5df264a52e5799c8a4de90be8c1cb5d00ed1e
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
* Silk 1.0.0
* A2plus 0.4.60k
* CurvedShapes 1.0.4
* MakerWorkbench 1.0.1
* freecad.gears 1.0.0
* Curves 0.6.8
* PieMenu 1.2.4
* toSketch 1.0.1
* Plot 2022.4.17
* AirPlaneDesign 0.4.0
* fasteners 0.4.54
* sheetmetal 0.2.63
- OffsetHolesInRectangle.FCStd
- (21.25 KiB) Downloaded 8 times
Re: Hole Pattern
Please, the 'count' in the path array is 11 but only 10 holes are shown.
It is my understanding that when you do a path array, an object is placed at both the beginning and end of the path. When the path is a closed loop, will that not result in a duplicate object?
If it is true that there is a duplicate, is it undesirable that this should be so?
Thanks.
Re: Hole Pattern
I see 11 holes.Workshop_Notes wrote: ↑Wed Mar 29, 2023 9:33 pm the 'count' in the path array is 11 but only 10 holes are shown.
No.
