[MERGED] Pre-commit hooks
agren
Re: Pre-commit hooks
Post by agren »
chennes wrote: Wed Mar 29, 2023 1:39 pm I had thought that by using a pip-installed version we could all use the latest, but the important thing is that especially for clang-format we have to pick a version, and then make our .clang-format file work with that version. For Black it's much less important because Black doesn't really have any options (that's its whole point).
I believe it is still important enough that everyone uses the same Black major version. There are almost no options, but the formatting rules might change between 21.x, 22.x, 23.x and so on.
Imagine a scenario where one pull request contain one line of behavior change. But 100 lines of code formatting changes.
It would also make compliance checks possible in the CI, if that's something that is planned.
Quote from the Black stability policy:
If code has been formatted with Black, it will remain unchanged when formatted with the same options using any other release in the same calendar year.
chennes
Post by chennes »
I have proposed that we use Black 22 and clang-format 15 in the actual YAML file (technically 22.10.0 and 15.0.7).
Chris Hennes
Pioneer Library System
Once the maintainers prepare their modules then issue #5578 should be done, too.
chennes
Post by chennes »
Black only normalizes line endings on a per-file basis. Do you want to add a hook to force Unix endings?
Chris Hennes
Well, many lint warnings are about that.
chennes
Post by chennes »
I'm happy to add it. If you can think of other formatting things want added right away let me know. I was thinking in the long-term it would be nice to write our own hook that checks the license of FCStd files that are getting committed.
Chris Hennes
chennes
Re: [MERGED] Pre-commit hooks
Post by chennes »
OK, I merged the PR with our pre-commit configuration file. It's now up to individual developers to enable it. Instructions are available in our new Developer's Handbook: https://github.com/FreeCAD/DevelopersHa ... evelopment
Chris Hennes
openBrain
Post by openBrain »
chennes wrote: Mon Apr 03, 2023 6:20 pm OK, I merged the PR with our pre-commit configuration file. It's now up to individual developers to enable it. Instructions are available in our new Developer's Handbook: https://github.com/FreeCAD/DevelopersHa ... evelopment
Do you think that on Debian/Ubuntu, it works as well to install with `apt install pre-commit` ?
Generally better use the package manager than pip. :)
chennes
Post by chennes »
Yes, most likely. The pre-commit docs themselves say to use pip so I was really just copying that. Feel free to submit a PR 8-) .
Chris Hennes
bernd
Post by bernd »
black on FEM Python code viewtopic.php?t=77747
