Hi, I need to crate a part_plane using 2 points as reference (each as a vertex of a plane, placed diagonaly). Is there a way to do it?
P.S points are selected randomly on a tube
Creating plane from 2 points
Re: Creating plane from 2 points
No a plane could be geometrically defined using three point.OlegTemple wrote: ↑Tue Mar 28, 2023 2:21 pm Hi, I need to crate a part_plane using 2 points as reference (each as a vertex of a plane, placed diagonaly). Is there a way to do it?
A line is defined from two points.
If you have selectable points on the tube you can attach the plane with attachment mode "Align O-X-Y". As noted, this will not be unique.OlegTemple wrote: ↑Tue Mar 28, 2023 2:21 pm Hi, I need to crate a part_plane using 2 points as reference (each as a vertex of a plane, placed diagonaly). Is there a way to do it?
An example may illustrate this:
The plane is attached to two opposite points of the heptagon: The plane can be turned around the connection line (file attached in this state):
- twoPointsPlane.FCStd
- (7.58 KiB) Downloaded 4 times
