MacOS, freecad 0.20.2
I want to place text on the polygon.
1. create body, sketch for polygon.
2. created pad and checked reversed in order for the polygon to be on the bottom of the text.
3. created the text in Draft workbench
4. positioned text.
5. I noticed that the ShapeString was same level as the Body. So i moved the ShapeString into the body. Thinking i could then manipulate the ShapeString in the Part Design workbench.
Now when i pad the ShapeString, it disappears, get a recompute failed message. select OK and tells me multiple objects are not supported.
I'm assuming because in item #5 moved into the Body?
Do I need another sketch for the Text?
This will be a drum badge attached to the exterior of the drum. (see attached pic a drum with badge, but mine will be a polygon shape). Not sure how to cut out the back of the polygon to fit the curvature of the drum?
still so much to learn....
Text on Part?
Text on Part?
- Screen Shot 2023-03-28 at 10.12.12 AM.png (370.74 KiB) Viewed 660 times
- Drum Badge 1.FCStd
- (19.84 KiB) Downloaded 7 times
Re: Text on Part?
Assuming the ShapeString is appropriately closed profile, no overlaps, T intersections, etc. it can be used in a Pad/Pocket/etc. with no sketch.
For a Pocket, it must not create multiple solids. This would void the single solid rule of Part Design.
Your pad operation must be such that all portions of the resulting letters will touch the previously existing solid.
- Screenshot_20230328_110414.png (38.63 KiB) Viewed 633 times
- papyblaise
Re: Text on Part?
either make a Pocket with the letters
either make a Pad in Part Wb and an add bolleen , or subtract boolleen
the 2em is faster to have letters of another color than the badge
in both cases, make the letters less thick than the badge so as not to lose the center of the O and the P
- badge.JPG (22.67 KiB) Viewed 616 times
- badge.FCStd
- (149.34 KiB) Downloaded 5 times
Re: Text on Part?
Also check photoetching technology and similiar ones. If badge is not going to be extra thick, then do it as flat and bend when assembling to drum.
Re: Text on Part?
thankx very much for your help !!papyblaise wrote: ↑Tue Mar 28, 2023 3:27 pm either make a Pocket with the letters
Re: Text on Part?
color changes:papyblaise wrote: ↑Tue Mar 28, 2023 3:27 pm either make a Pocket with the letters
If I Select pad or text, right clicked Appearance and changed color. Color not applied? It just happened that i changed text positions, and colors then applied?
Is there a setting for this to apply when Appearance dialog is closed?
- papyblaise
Re: Text on Part?
to change the colors, I couldn't find better than to erase the cut, change the colors of each element and redo the cut
at least that's a solution
- badge jaune.JPG (15.93 KiB) Viewed 367 times
Re: Text on Part?
OK, thankx for checking!! I thought maybe doing a recompute on the object would refresh the object also.papyblaise wrote: ↑Thu Mar 30, 2023 3:34 pm to change the colors, I couldn't find better than to erase the cut, change the colors of each element and redo the cut
Also, I guess if I wanted to change the text, I probably need to delete and redo the cut? I created my own badge with multiple text, created a union, then did a cut. Unfortuntley, i can't attach the file because it exceeds the 1MB limit.
thankx again!!
