Part.makeWireString issue with unicode file name
Roy_043
Post by Roy_043 »
In V0.21 Part.makeWireString can no longer handle a unicode character in the filename. The code below works in V0.20, but not in the mentioned V0.21 version.
import Part
Part.makeWireString("abc", "D:\\FreeCAD\\PR0000-draft-decode\\FreeMonoé.ttf", 10, 0)
Version: 0.21.0.32457 (Git)
Hash: 85216bd12730bbc4c3cbf8f0bc50416ab1556cbb
Python 3.10.9, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: English/United States (en_US) [ OS: Dutch/Netherlands (nl_NL) ]
Syres
Re: Part.makeWireString issue with unicode file name
Post by Syres »
Roy_043 wrote: Tue Mar 28, 2023 12:51 pm In V0.21 Part.makeWireString can no longer handle a unicode character in the filename. The code below works in V0.20, but not in the mentioned V0.21 version.
I can completely confirm your findings on Windows using the latest LibPack build 32552 but on all 4 of my Linux builds (OCC 7.3.0, 7.6.3, 7.7.0 and 7.7.1) I can open and change the same file I was using as a test on Windows (with the folder changed to suit). So from initial findings, either platform specific or a packaging issue???
Version: 0.21.0.32593 (Git)
Hash: c26dc2e68534e96b2b5482afa8f414170df4e593
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.7.1
  * Silk 1.0.0
  * A2plus 0.4.60k
  * CurvedShapes 1.0.4
  * MakerWorkbench 1.0.1
  * freecad.gears 1.0.0
  * Curves 0.6.8
  * PieMenu 1.2.4
  * toSketch 1.0.1
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * fasteners 0.4.54
  * sheetmetal 0.2.63
wandererfan
Post by wandererfan »
I am not near my windows vm. Could you please try:
import Part
Part.makeWireString("abc", "D:/FreeCAD/PR0000-draft-decode/FreeMonoé.ttf", 10, 0)
and let me know what happens? Thanks.
Roy_043
Post by Roy_043 »
@Syres Thanks for testing.
@wandererfan The new path results in the same error.
wandererfan
Roy_043 wrote: Tue Mar 28, 2023 5:17 pm The new path results in the same error.
I'm thinking it is one of these 2 commits:
ucs4 vs ucs2 in Py3.10: git commit 3b29cf18be
temp files on windows: git commit c318bc08cb
Probably the second one. I'll look into it.
wandererfan
Should be fixed by git commit 7fa7cb7f0b22.
Roy_043
Post by Roy_043 »
Thank you.
