Can't Export or add a final fillet - "Out of allowed scope" error
gallinka
Post by gallinka »
I have tried to create this part several times. It is a simple design, basically a grommet for wire. There is a 3" diameter (76.2mm) 3/16" (4.7mm) thick "flange" with a 2" diameter hole in the center and a 3/16" of an inch wall thickness. The overall part is 14.28mm (3/16"/4.7mm for the flange, plus 3/8"/9.5mm deep hole).
So I created a sketch, drew a circle, and constrained it to 76.2 mm. I pad that to 4.7mm. I create another sketch (in the same body), draw a circle, constrained it to 55.56mm, and pad the sketch to 14.28mm. I then create a subtractive cylinder, 25.4mm in radius, 14.28mm deep (on the xy plane I think, I don't understand fully the dialog that opens up).
I get this error when I try to add a fillet:
23:12:02  Part::Fillet: Link(s) to object(s) 'Cylinder' go out of the allowed scope 'Fillet'. Instead, the linked object(s) reside within 'Body Body'.
23:13:01  1e-07 <App> Document.cpp(3216): The graph must be a DAG.
23:13:01  0.175947 <App> Document.cpp(3571): __inch_wire_grommet_flange#Fillet still touched after recompute
23:13:01  0.177074 <App> Document.cpp(3216): The graph must be a DAG.
23:13:01  Part::Fillet: Link(s) to object(s) 'Cylinder' go out of the allowed scope 'Fillet'. Instead, the linked object(s) reside within 'Body Body'.
23:13:01  Recompute failed! Please check report view.
23:15:28  147.289 <App> Document.cpp(3216): The graph must be a DAG.
23:16:21  200.109 <App> Document.cpp(3216): The graph must be a DAG.
23:16:43  Recompute failed! Please check report view.
23:17:14  Recompute failed! Please check report view.
23:17:43  Recompute failed! Please check report view.
23:17:59  Recompute failed! Please check report view.
23:18:39  Recompute failed! Please check report view.
23:21:00  Recompute failed! Please check report view.
23:21:08  Recompute failed! Please check report view.
23:32:12  Recompute failed! Please check report view.
23:36:29  <Exception> Tree.cpp(2005): Dependency loop detected for Unnamed#Pad001
23:37:36  <ShapeBinder> ViewProviderShapeBinder.cpp(363): invalid selection
23:39:23  Recompute failed! Please check report view.
I also cannot export the drawing to an STL. I think the two pad operations are not bound to each other or something but honestly, this is all beyond me. I have no background in CAD and I have only been learning CAD/FreeCAD for a few weeks. Any help would be appreciated.
Re: Can't Export or add a final fillet - "Out of allowed scope" error
gallinka wrote: Tue Mar 28, 2023 3:59 am ...
A file and some FreeCAD info following.
http://forum.freecadweb.org/viewtopic.php?f=3&t=2264
would be a good help to pinpoint the problem.
And if you use the <\> button to post code it will be more readable.
Help us to help you, as helpers here are smart, but voukd not yet read minds.
Kind Regards
You have a cyclic dependency ("not a DAG"). Check the Dependency Graph for red arrows.
Out of allowed scope occurs, if you cross the Body unallowed, e.g. by applying a Part fillet to a PartDesign feature. These are shown in orange in the dependency graph.
gallinka
Post by gallinka »
I am running FreeCAD version 20.2. I had to re-create the file. I could not remember how I subtracted the cylinder so I had to subtract a cylinder from both pad operations to get it to make a hole. I could only add a fillet to one of the cylinders, the other produced the error. Here is the file:
2inchgrommetflange.FCStd
(22.3 KiB) Downloaded 12 times
chrisb wrote: Tue Mar 28, 2023 8:57 am
I installed Graphviz and looked at it. It shows two bodies, fully contained in a box. I am not sure even if that is good or bad.
Thanks in advance for any help you can provide.
I don't see the DAG error in your file, but the fillet issue is exactly as suspected above. To repair:
- Delete Fillet
- make Body invisible
- make Body001 visible
- activate Body001 (this will also switch workbench)
- add a PartDesign fillet.
papyblaise
Post by papyblaise »
There are several reasons why it doesn't work:
the 2 bodies must be merged (Add boolean)
fillet only at the end
make the fillet in the same body and with PartDesign
there is a more logical workflow:
make the 1st Pad with a sketch that already contains the circle of the hole, make the 2nd cylinder in the same body by also making the hole at the same time, then the fillet
another solution: draw the section of the tube with its flange and the fillet, and rotate it
your finished version with the 1st solution:
2inchgrommetflange finished.FCStd
(23.72 KiB) Downloaded 9 times
2inchgrommetflange finished.JPG (23.18 KiB) Viewed 412 times
Shalmeneser
Post by Shalmeneser »
:idea:
2inchgrommetflange_SHALM.FCStd
(9.78 KiB) Downloaded 10 times
Capture d’écran 2023-03-28 192238.jpg (29.68 KiB) Viewed 313 times
