Showmainwindow not working in freecadcmd
carlos.costacano
Post by carlos.costacano »
Hello
I have been playing around with FreeCAD for a while now, this time I don't know how to solve this problem
my main goal is to automate certain tasks with FreeCAD, and I would like to use freeCADcmd, so I can make the calls from anywhere I want, but when I try to show the GUI with Gui.showMainWindow() I get this in the log
Log: All modules with GUIs using InitGui.py are now initialized
Log: All modules with GUIs initialized using pkgutil are now initialized
Log: Init: Loading FreeCAD GUI
Log: Init: Running FreeCADGuiInit.py start script... done
Log: Init: Activating default workbench
Log: Loading GUI of Web module... done
Log: Loading GUI of Start module... done
Log: Loading Start module... done
Log: WebEngineContext used before QtWebEngine::initialize() or OpenGL context creation failed.
Err: Exception while processing file: C://Development//Qt//mainwindow//test.py [Illegal storage access! Please save your work under a new file name and restart the application!]
Log: Exiting on purpose
Log: FreeCAD terminating...
looking for this error in internet seems related with Qt
Is there anyway to use the FreeCAD instance that is already open?
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
Locale: English/New Zealand (en_NZ)
Re: Showmainwindow not working in freecadcmd
If use freecadcmd you have no Gui as it is the headless version of FreeCAD, you could import FreeCADGui, there are some hints probably on the wiki in the power users section.
And in some old @wmayer posts.
I do get this warning too but FreeCAD doesn't crash.
I wonder what is test.py doing? Could this be the culprit doing something forbidden?
To rule out the Start module as the problem you can change your start workbench. Therefore start FreeCAD normally and change the default startup workbench in the preferences. Then try FreeCADCmd again.
Syres
Post by Syres »
wmayer wrote: Tue Mar 28, 2023 10:09 am I do get this warning too but FreeCAD doesn't crash.
I've been having a look at an issue issue #9086 and it can't be a coincidence that testing the two builds quoted in reply produce the same results in that Version: 0.21.31155 (Git) Approx 2nd Dec 2022 starts a main window in FreeCADcmd:
import FreeCADGui as Gui
but following the same procedure with Version: 0.21.0.31850 (Git) Approx 12th Feb 2023 produces the
<Exception> Access Violation
You'll note the git commit 2f575a3 is the one that stood out to me as it's Windows specific but that's purely a hunch.
carlos.costacano
sorry I forgot to put this code of test.py, is just
I have changed the start workbench to none and still happens
carlos.costacano
I have been looking into this problem, looks like showMainWindow may work or not depending on the system and version because it is not intended to work in this way in freecadcmd
I have seen other people trying this way, because it is a good way to develop a bigger app that uses FreeCAD in the background for some aspect of the app but not being the main part
I already started a workbench development to do what I need, the first problem I face is how to install other pyhton modules I need, I don't find a clear explanation how to do this, other post suggest to paste the library folders in the correspondent FreeCAD sitepackages, this has worked for the the first library I need, but it may not work with others I may need in the future, I have found older post talking about this but not official way of doing it
i would like to suggest to improvements for FreeCAD:
-embedding FreeCAD in other Apps
-install extra libraries in FreeCAD
CharlesM
Post by CharlesM »
Any improvement on this problem @carlos.costacano ? At my work we are facing the same issue. We are developing a FreeCAD/Qt app and for some reason, it wont works on some computer.
From inside freecadcmd.exe :
Just fails.
We tried to update them from Windows 10 to 11 without success. On other computers, it works flawlessly.
Any suggestions ?
EDIT : We just checked , it seems to be a bug on the release Version: 0.20.2.29603 (Git) , we downgraded to Version: 0.20.2.29177 +426 (Git) , and it seems to work.
carlos.costacano
thanks for the info
I have started the development of a workbench after not being able to solve it, I don't think I am going to try the other way for a while
