Where are paths rendered to 3d-view?
freman
Post by freman »
I'm trying to find out where individual paths are rendered to the 3d-view. I've just spent about an hour grepping and have not been able to find it.
It appears that drilling paths may not be correctly rendered if G99 is active. They retract like G98 instead of stopping at R value. I wanted to check out what was happening but can't find where this is done.
If anyone who knows their way around can indicate where to look that would be very helpful.
TIA.
MRx
Re: Where are paths rendered to 3d-view?
Post by MRx »
What do you mean with not correctly rendered?
In my case the path for my custom command didn't get rendered at all until I modified PathSegmentWalker.cpp.
I added a custom command to linuxcnc (I'm using the B axis stepper motor to turn the spindle), G84.1 in order to make it visible in FreeCAD I had to update PathSegmentWalker as well.
+++ b/src/Mod/Path/App/PathSegmentWalker.cpp
@@ -275,7 +275,7 @@ void PathSegmentWalker::walk(PathSegmentVisitor &cb, const Base::Vector3d &start
             // relative mode
             absolutecenter = false;
-        } else if ((name=="G81")||(name=="G82")||(name=="G83")||(name=="G84")||(name=="G85")||(name=="G86")||(name=="G89")){
+        } else if ((name=="G81")||(name=="G82")||(name=="G83")||(name=="G84")||(name=="G85")||(name=="G86")||(name=="G89")||(name=="G84.1")){
             // drill,tap,bore
             double r = 0;
             if (cmd.has("R"))
freman
Post by freman »
Ah, many thanks. That explains why I could not find it . I was looking in the python code.
It needs to take account of G99/98 mode in force and it does not appear to be doing this. It always shows a full retraction.
Thanks for the tip.
freman
Post by freman »
many thanks to MRx.
I now have 3Dview G98/G99-aware. Most of effort was finding where to do it. The mods needed were minimal.
A bit more testing and I'll submit a PR.
            Base::Vector3d p3(next);
            if (retract_mode == 99)
                p3.*pz = p2.*pz;
            else
                p3.*pz = last.*pz;
        } else if(name=="G19") {
            pz = &Base::Vector3d::x;
        } else if(name=="G98") {
            retract_mode = 98;
        } else if(name=="G99") {
            retract_mode = 99;
