Proposal: add gmsh boundary layer meshing to CfdOF.
Moderator: oliveroxtoby
techGuy
Post by techGuy »
See here: https://github.com/jaheyns/CfdOF/issues/78
Thoughts, advice ?
NewJoker
Re: Proposal: add gmsh boundary layer meshing to CfdOF.
Post by NewJoker »
That would be very useful. Especially if Gmsh can create good-quality boundary layer mesh in 3D (I haven't seen such an example yet). And maybe the code from the CFD workbench (discussed in that referenced thread) could help.
thschrader
Post by thschrader »
techGuy wrote: Mon Mar 27, 2023 9:03 pm See here: https://github.com/jaheyns/CfdOF/issues/78
Thoughts, advice ?
A thought...
With cfmesh you can produce a tetrahedral mesh too, with boundary elements.
After writing the meshCase, use Edit, open the Allmesh-script and change
"runCommand cartesianMesh" to "runCommand tetMesh".
Save file, Run Mesher.
Works even for polyhedral meshes with "runCommand pMesh".
See also cfmesh user-guide.
techGuy
Post by techGuy »
thschrader wrote: Wed Mar 29, 2023 3:46 pm See also cfmesh user-guide.
Where is the latest cfmesh user guide ? The one I am using is circa 2015.
techGuy
Post by techGuy »
thschrader wrote: Wed Mar 29, 2023 3:46 pm A thought...
If it is literally that simple, it would be very easy to add this as an option in the mesh control panel and to the mesh object and processes.
oliveroxtoby
Post by oliveroxtoby »
techGuy wrote: Wed Apr 05, 2023 6:24 pm
I think it is that simple, but I have found the tet mesher a bit wanting in terms of robustness (in my admittedly limited experience) so have avoided adding it as an official option.
oliveroxtoby
techGuy wrote: Wed Apr 05, 2023 5:54 pm
I think that is the only one. The free version of the official code (https://sourceforge.net/p/cfmesh/code/c ... ment/tree/) was abandoned a while ago.
techGuy
Post by techGuy »
oliveroxtoby wrote: Wed Apr 05, 2023 7:06 pm
Good to know ! I lack the historical knowledge on these issues. Comments like this are very helpful.
