I'm new to FreeCAD and wanted to create a tiling as shown in the picture. I didn't know better and created the model by just copy pasting and precisely overlapping pockets. To improve in the future I want to know what the proper way of creating such a tiling is (I couldn't get the Array to work as I wanted).
Thanks for your knowledge.
How can I create a tiling like this
- Capture.PNG (39.17 KiB) Viewed 767 times
Re: How can I create a tiling like this
It's a bit tricky pattern. Here's a solution using the Expression Array in Assembly4. Sizes, columns and rows can be adjusted in the parameters of the Variables object. The cut tool is a fusion with an expression on Shapes that links it to ElementList of the "XArray_Fusion". The placement of the tiles is controlled by expressions inside Placer property of "XArray_Fusion"
- hexpattern_Jolbas.FCStd
- (148.02 KiB) Downloaded 17 times
Make one cutting shape and use the Lttice2 workbench.
Done with Draft Array tools: Array, Point Array and Polar Array.
Make an array of points for the tile centers (one 6 x 3, one 5 x 3 displaced. Dimensions, offsets all come from Sketch as a reference.
Extrude a hexagon.
Polar array the edge blocks and extrude.
Use the point array to distribute over the tiling.
Lattice 2 would be good, too.
Extrude a hexagon.
- HexTiling.FCStd
- (136.18 KiB) Downloaded 12 times
A little tidier as you can join the array with its displaced version before populating with copies.
- HexTilingLattice2.FCStd
- (28 KiB) Downloaded 7 times
Just some (2) pockets and 2 multitransforms.......
- tilesPD.FCStd
- (459.31 KiB) Downloaded 14 times
Two more ways of creating the hex mesh of placements to loop over.
1) 3 nested arrays:
1) 3 nested arrays:
- 6 elements array along x
- repeat 2 times diagonally
- repeat 5 times in y
- 12 elements diagonally
- repeat 11 times in y symmetrically
- Choose elements in the final rectangle
- hexlattice2.FCStd
- (22.68 KiB) Downloaded 6 times
