FreeCAD suddenly won't start - how to debug ?
Boo
Post by Boo »
I am running FreeCAD 0.20.2 which was working great but suddenly it refuses to start. The splash screen shows up and gets as far as "Loading PathToolController... Initialising c:\Users\..." but then it disappears and the "FreeCAD Main Program" in the Windows Task Manager disappears too. Nothing further happens and I cannot see anything relating to FreeCAD in WTM after that point.
Can anyone give me any pointers how to proceed to debug/resolve this issue please ?
The last time I posted here I was Using:
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
  * A2plus 0.4.60g
  * Assembly3 0.11.4
  * Assembly4 0.12.5
  * BOLTSFC
  * Curves 0.6.5
  * fasteners 0.4.27
  * fcgear 1.0.0
  * kicadStepUpMod 10.16.5
  * MakerWorkbench
  * Manipulator 1.4.9
  * parts_library
  * Plot 2022.4.17
  * ThreadProfile 1.84.0
  * WebTools
but my current splash screen shows 0.20.2 as I posted above.
Thanks,
Boo
Re: FreeCAD suddenly won't start - how to debug ?
Start FreeCAD from the command line and pass the option --write-log. This will create the file FreeCAD.log under %APPDATA%\FreeCAD and may contain some information about what's going on.
Boo
Post by Boo »
wmayer wrote: Mon Mar 27, 2023 6:07 pm Start FreeCAD from the command line and pass the option --write-log. This will create the file FreeCAD.log under %APPDATA%\FreeCAD and may contain some information about what's going on.
OK, thank you very much. I have done what you suggest and (after changing the User from my name to "UserME" and deleting the path) I have attached the file as "FreeCAD.log.edited.txt".
From the error message it seems to be an issue with "\MakerWorkbench", can anyone suggest a way forward for me ? I seem to remember that I recently updated this workbench but it is not one that I use, I just wanted to play with it...
Thanks again,
Boo
(12.09 KiB) Downloaded 16 times
chennes
Post by chennes »
You can remove that workbench by deleting its folder from USER/AppData/Roaming/FreeCAD/Mod, or you can disable it by creating a file called ADDON_DISABLED (no content necessary) in its Mod folder. then try to start FreeCAD again.
Chris Hennes
Pioneer Library System
Boo
Post by Boo »
chennes wrote: Mon Mar 27, 2023 7:24 pm You can remove that workbench by deleting its folder from USER/AppData/Roaming/FreeCAD/Mod, or you can disable it by creating a file called ADDON_DISABLED (no content necessary) in its Mod folder. then try to start FreeCAD again.
Thanks, that worked and I am going again.
Boo
BezdaM
Post by BezdaM »
Hello, I have problem too
log.txt
(61.66 KiB) Downloaded 20 times
chennes
Post by chennes »
I don't think that's the same error -- it looks to be some sort of problem with the Start workbench, maybe? It doesn't look like you have any 3rd party addons installed.
Chris Hennes
