thomas-neemann
Posts: 11958 Joined: Wed Jan 22, 2020 6:03 pm
Post
by thomas-neemann » Mon Mar 27, 2023 5:56 pm
this file was created by multiple nested part compounds. when i export it as ifc it is incomplete. what can be the cause?
Version: 0.20.2.29603 (Git) AppImage
* Curves 0.6.8
thomas-neemann on Tue Mar 28, 2023 10:06 am, edited 3 times in total.
Roy_043
Posts: 8579 Joined: Thu Dec 27, 2018 12:28 pm
Post
by Roy_043 » Mon Mar 27, 2023 8:27 pm
The compound contains 27 solids and 835 unconnected faces (some of these elements are nested in sub-compounds). Only the solids end up in the IFC. If you
Draft_Downgrade the compound you end up with the same 27 solids.
bernd
Posts: 12851 Joined: Sun Sep 08, 2013 8:07 pm
Post
by bernd » Tue Mar 28, 2023 1:51 am
exactly.
Attached a simple file which shows the problem ... The Shells would have been exported if you would not use one huge compound object out of Shapes but a compound from document objects.
thomas-neemann
Post
by thomas-neemann » Tue Mar 28, 2023 5:55 am
bernd wrote: ↑ Tue Mar 28, 2023 1:51 am
Roy_043 wrote: ↑ Mon Mar 27, 2023 8:27 pm
thank you for the hints. Always paying attention to solids is too tedious and too slow for me. here is a workaround, but the ifc result is a wireframe.
1st step export as dxf
2nd step import dxf and export as ifc
Roy_043
Post
by Roy_043 » Tue Mar 28, 2023 7:14 am
thomas-neemann wrote: ↑ Tue Mar 28, 2023 5:55 am
Your workaround is ill-advised. With a wireframe representation you cannot even distinguish an opening from a closed panel!
thomas-neemann
Post
by thomas-neemann » Tue Mar 28, 2023 7:30 am
Roy_043 wrote: ↑ Tue Mar 28, 2023 7:14 am
...With a wireframe representation you cannot even distinguish an opening from a closed panel!
that's no problem. archicad can e.g. also import stl. the ifc file is suitable for referencing. so everything is recognizable.
Roy_043
Post
by Roy_043 » Tue Mar 28, 2023 7:47 am
In a more complex model using wireframe is simply not an option.
thomas-neemann
Post
by thomas-neemann » Tue Mar 28, 2023 7:50 am
Roy_043 wrote: ↑ Tue Mar 28, 2023 7:47 am
is there another workaround?
Roy_043
Post
by Roy_043 » Tue Mar 28, 2023 7:53 am
Instead of relying on a workaround, pay attention to solids.
thomas-neemann
Post
by thomas-neemann » Tue Mar 28, 2023 8:00 am
Roy_043 wrote: ↑ Tue Mar 28, 2023 7:53 am
here is a workaround where everything is visible.
convert the mesh with create shape from mesh (in part workbench). export the result as an ifc
