[SOLVED] error compiling FC0.21 daily on Mint 20.3 Cinnamon
easyw-fc
Post by easyw-fc »
Hi, I'm trying to compile FC0.21 daily on Linux Mint 20.3 Cinnamon based on Ubuntu 20.04
following the compile on Linux wiki:
https://wiki.freecad.org/Compile_on_Linux
for Debian/Ubuntu
I did:
sudo apt install cmake cmake-gui libboost-date-time-dev libboost-dev libboost-filesystem-dev libboost-graph-dev libboost-iostreams-dev libboost-program-options-dev libboost-python-dev libboost-regex-dev libboost-serialization-dev libboost-thread-dev libcoin-dev libeigen3-dev libgts-bin libgts-dev libkdtree++-dev libmedc-dev libocct-data-exchange-dev libocct-ocaf-dev libocct-visualization-dev libopencv-dev libproj-dev libpyside2-dev libqt5opengl5-dev libqt5svg5-dev qtwebengine5-dev libqt5x11extras5-dev libqt5xmlpatterns5-dev libshiboken2-dev libspnav-dev libvtk7-dev libx11-dev libxerces-c-dev libzipios++-dev occt-draw pyside2-tools python3-dev python3-matplotlib python3-packaging python3-pivy python3-ply python3-pyside2.qtcore python3-pyside2.qtgui python3-pyside2.qtsvg python3-pyside2.qtwidgets python3-pyside2.qtnetwork python3-pyside2.qtwebengine python3-pyside2.qtwebenginecore python3-pyside2.qtwebenginewidgets python3-pyside2.qtwebchannel python3-markdown python3-git qtbase5-dev qttools5-dev swig pyside2-tools pyqt5-dev-tools
and then I've done:
cd ~/Downloads
git clone https://github.com/FreeCAD/FreeCAD.git FreeCAD-src
mkdir FreeCAD-build
cd FreeCAD-build
cmake ../FreeCAD-src
I've got the following errors:
-- Configuring done
CMake Error in src/Base/CMakeLists.txt:
  Imported target "Boost::filesystem" includes non-existent path
    "/include"
  in its INTERFACE_INCLUDE_DIRECTORIES.  Possible reasons include:
  * The path was deleted, renamed, or moved to another location.
  * An install or uninstall procedure did not complete successfully.
  * The installation package was faulty and references files it does not
  provide.
here is my PATH var:
echo $PATH
/sbin:/bin:/usr/bin:/usr/local/bin
EDIT: I've solved with:
cmake -DBoost_NO_BOOST_CMAKE=TRUE ../FreeCAD-src
https://stackoverflow.com/questions/301 ... stallation
