GUI issue in AppImage - cannot edit property value
FCuser0
Post by FCuser0 »
I am facing issue with editing properties. Basically, the property/value table looks ok. But when I click an entry, the edit box is misaligned and I can neiterh click the fx button not the up/down arrows to change the value.
This is under Kubuntu 22.04. I have no issues with any other application. I guess it must be related to the font settings, but I don't know how I change these for the AppImage (I use the 0.20.2 AppImage)
Re: GUI issue in AppImage - cannot edit property value
As soon as you have an Attachment, you have to make all changes to the AttachmentOffset, which is relative to the Placement.
the UI glitch is not normal though. Are you suing some addon? does this happen in an editable field like the attachment offset too?
MisterMaker
Post by MisterMaker »
This seems to be an issue with my theme, some spinbox select settings are doing weird. :cry:
Tnx for reporting I'll try and fix it.
Edit: It should be fixed mostly.
There can still pop up a lost cursor, but it's not that annoying. There are a bunch of hacks in the older theme files, but I rather only copy/paste the ones that actually do something.
