No such file or directory: 'C:\\....Templates\\Asm4_infoPartConf.json'
Locked
IemandAnders
Post by IemandAnders »
09:47:33  Running the Python command 'Asm4_makeBOM' failed:
  File "C:\Users\admin\AppData\Roaming\FreeCAD\Mod\Assembly4\.\makeBomCmd.py", line 91, in Activated
    file = open(ConfUserFilejson, 'r')
[Errno 2] No such file or directory: 'C:\\Users\\admin\\AppData\\Roaming\\FreeCAD\\Templates\\Asm4_infoPartConf.json'
Version: 0.21.0.32552 (Git)
Hash: e2b3a5d2f791fb78a61daac9bdab374058f682f2
  * Assembly4 0.12.6
Syres
Re: No such file or directory: 'C:\\....Templates\\Asm4_infoPartConf.json'
Post by Syres »
Why have you logged a duplicate topic to viewtopic.php?t=77123 yesterday? If the step-by-step procedure I gave didn't work at the very least post in that topic the error or if nothing happened. I even gave a suggested fix which you could have applied to your local install of ASM4, this does require a restart of FC to be brought into effect.
IemandAnders
Syres wrote: Mon Mar 27, 2023 9:27 am Why have you logged a duplicate topic to viewtopic.php?t=77123 yesterday? If the step-by-step procedure I gave didn't work at the very least post in that topic the error or if nothing happened. I even gave a suggested fix which you could have applied to your local install of ASM4, this does require a restart of FC to be brought into effect.
Calm down!
IemandAnders wrote: Mon Mar 27, 2023 9:35 am Calm down!
Don't call others to order, if you made yourself the mistake.
Topic locked.
Locked
