Gear Workbench
HtRabbit
Gear Workbench
Post by HtRabbit »
I am using the Gear workbench
trying to get the worm wheel to have an arch or curvature to match the wormgear. i cannot find any settings for this.
i am also try to figure a good way to find the center of the gear.
OS: Windows 10 Version 1909
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
  * 3DfindIT 1.2.0
  * 3D_Printing_Tools
  * A2plus 0.4.59
  * Assembly4 0.12.4
  * CADExchanger
  * CurvedShapes 1.0.4
  * Curves 0.5.8
  * Defeaturing 1.2.0
  * fasteners 0.4.6
  * fcgear
  * Help 1.0.3
  * Manipulator 1.4.9
  * parts_library
  * pcb
SwingGear.FCStd
(921.06 KiB) Downloaded 8 times
There is no Gravity....Taxes Suck!
Workshop_Notes
Re: Gear Workbench
Post by Workshop_Notes »
HtRabbit wrote: Sun Mar 26, 2023 8:07 pm trying to get the worm wheel to have an arch or curvature to match the wormgear.
I am also try to figure a good way to find the center of the gear.
There are commonly four arrangements of worm and wheel:
https://roymech.org/Useful_Tables/Drive/Worm_Gears.html
The FC gear module does not have the ability to produce all four.
In your file, the 'placement' of the wheel is its centre (0,0,0). Right click in the tree and choose 'transform' (works similarly for the worm).
papyblaise
Re: Gear Workbench
Post by papyblaise »
you have to make an arc sector equal to one tooth (green on my photo), subtract the screw and make an Array to make the total, I only made 1/4 of it to have a 1GB file
SwingGearPPB.FCStd
(899.26 KiB) Downloaded 7 times
HtRabbit
Re: Gear Workbench
Post by HtRabbit »
so for a 100 tooth gear i need 3.6 deg per tooth....correct?
SwingGear1.FCStd
(368.26 KiB) Downloaded 9 times
here is what i did. it looks great however i need to edit the gear and combine every thing into a single part so i can add the axle holes etc.
