Bumpy 3D surface
Joneb
Bumpy 3D surface
Post by Joneb »
Hi Can anyone see what I have done wrong to get this bumpy surface, it,s not a major problem and can be sanded out but it would be nice if it was smooth.
I roughed out the bulk of the matrial with a 6mm ball cutter to the finished depth using the offset stratergy wit a 50% stepover then finised off with a circular stratergy with a 10% stepover. The material is hard wood and it is for a fibre glass mould.
As you can see from the GCode snippet the z axis variation gives the bumps.
Version: 0.21.31155 (Git)
Hash: 6f1b29769b33676edca2bd883b80bed25a0758c8
Python 3.8.15, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * Assembly4 0.12.4
  * FeedsAndSpeeds-master 0.4.0
Thankyou to all the team for all the work on Path
Regards John
MouldFrontFinish.FCStd
(1014.94 KiB) Downloaded 26 times
bmsaus4ax
Re: Bumpy 3D surface
Post by bmsaus4ax »
Joneb wrote: Sun Mar 26, 2023 6:06 pm Hi Can anyone see what I have done wrong to get this bumpy surface, it,s not a major problem and can be sanded out but it would be nice if it was smooth.
An apparently strange question to begin with : does your gcode file, toolcontroller entry say "bullnose" tool ?
( bullnose tools give this result)
Your posted image shows a Ball endmill, but the uploaded file operation is stll using a Bullnose tool.
The generated path does not seem to be able to properly interpolate the combined flat and radial face of a bull nosed tool.
The bumpy surface results with a Bullnose shape
A smooth surface is possible with a Ball nose shape
bmsaus4ax wrote: Sun Mar 26, 2023 10:05 pm A smooth surface is possible with a Ball nose shape
Good find. You probably mean a Ball end mill here.
I had also tried with a smaller sample interval. That makes things worse:
bmsaus4ax
Post by bmsaus4ax »
chrisb wrote: Sun Mar 26, 2023 10:30 pm
In theory a Bullnose could be made to work if the stepover and step down were small enough to be within the radius of the radial corner face (the size of the radius not the physical radial position )
I have not tried this due to the processing and run times that would result. 3D surface is already pretty time intensive.
xemul
Post by xemul »
IMO more convenient way is to make profiling for pads by a finest available tool and waterline for the rest.
You'll need to play with step down and sample interval in waterline operation.
I'm sorry for rough example, but I'm roped to antique L501x laptop at a moment, and any path calculations are really painful.
Profile paths from 3D Surface (Profile edges: Only) have a strong hiccup. I'm not a pythonist but try to look at a cause.
MouldFrontFinish_xemul.FCStd
(836.73 KiB) Downloaded 22 times
Joneb
Re: Bumpy 3D surface (Solved)
Post by Joneb »
Thankyou every body for your replies my stupid mistake I thought I had set the tool to ball end as I new the problem with bull
John
