TechDraw dimension axis selection
ytrottier
Post by ytrottier »
How do I change the axis of a diagonal dimension in TechDraw? See the stock length dimension in the example below. I want that 8' 10+3/4" dimension to be measured on an axis parallel to the longest line on the part. It's pretty close in this example, but that's just luck, and I have other parts where I won't be so lucky. TechDraw defines the measurement axis by a straight line from point to point. How do I override that?
OS: macOS Mojave (10.14)
Version: 0.20.2.29603 (Git)
Locale: C/Default (C)
  * Assembly4 0.12.6
dimension axis.png (102.15 KiB) Viewed 1085 times
domad
Re: TechDraw dimension axis selection
Post by domad »
ytrottier wrote: Sun Mar 26, 2023 5:52 pm ....
Hello ytrottier, greetings to the Community!
Welcome to the forum and to FreeCad.
I advise you to read the regulation, then respecting what you have read, insert the data of your system and the version of FreeCad you are using.
I hope the animated gif helps your request.
ytrottier
Post by ytrottier »
Thank you. I added my version information to my OP above. From your animated gif, it looks like the key is that "Axonometric length dimension" button. I don't have that button. Is that an add-on that I'm missing?
NewJoker
Post by NewJoker »
It was added very recently. It can be found in weekly builds: https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds
wandererfan
Post by wandererfan »
ytrottier wrote: Sun Mar 26, 2023 5:52 pm How do I change the axis of a diagonal dimension in TechDraw?
In v0.20 the dimension line is not adjustable. In v0.21, you would use the dimension edit dialog to set angles to a non-standard layout.
domad
Post by domad »
ytrottier wrote: Sun Mar 26, 2023 8:45 pm Thank you. I added my version information to my OP above. From your animated gif, it looks like the key is that "Axonometric length dimension" button. I don't have that button. Is that an add-on that I'm missing?
Greetings to the Community!
Here the latest weekly release https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds where you will find the function
domad
Post by domad »
In connection with the topic, I am attaching a general example (usable in any eventuality) of inclined dimensioning (of any angle) referred to any edge, using the TD function "Axonometric length dimension".
I hope the animated gif is exhaustive enough.
A_general_example_of_sloped_sizing.FCStd
(20.77 KiB) Downloaded 24 times
ytrottier
Post by ytrottier »
Thank you, @domad, your gif is very clear and helpful. I'm going to make do for now and wait until the feature is in an official update.
I'm guessing that @wandererfan's solution would only tilt the dimension lines, not actually change the measurement axis? In any cases, it also needs the next release.
domad
Post by domad »
In my opinion this topic should be moved to the specific TechDraw forum, could a moderator kindly intervene if he deems it useful?
ytrottier
Post by ytrottier »
I found a better way, using "Create Oblique Coordinate Dimensions". The first two points you pick establish the measurement axis, and then you can pick the two points you actually want to measure from. This will create cosmetic lines and measure from those. Delete the two superfluous dimensions and you're done.
forum gif.gif (699 KiB) Viewed 597 times
