[solved] TechDraw Center lines not created/shown for holes
Re: TechDraw Center lines not created/shown for holes
Shalmeneser wrote: Tue Mar 28, 2023 10:13 am Where does it come from ?
@akredd, how did you align the object before adding the projection group?
akredd
Post by akredd »
chrisb wrote: Tue Mar 28, 2023 10:06 am It is an alignment problem. Look at the Front Direction. It shows in the Z component -0.000 (I use three decimals). The "-" indicates that there is a minuscule negative deviation from the "real" zero. Set it explicitely to 0 shows the centermarks.
Hi, to all helped here.
That was it. My next question was solved before i can ask :lol: I got a problem with a section that was not properly shown. The same thing, a "-" in Section Normal. But i didn't get any idea how that "-" come in the Data. I'm shure i didn't change that... In the Future i will have a glance on that.
Thanks to all and regards
Andreas
akredd
Post by akredd »
chrisb wrote: Tue Mar 28, 2023 10:20 am @akredd, how did you align the object before adding the projection group?
I position the part with shortkey 3 (right view). I don't know yet if i create the page before or after that. Than i create the projection group.
Andreas
akredd wrote: Tue Mar 28, 2023 10:29 am I position the part with shortkey 3 (right view). I don't know yet if i create the page before or after that. Than i create the projection group.
That works here out of the box. So it's probably a rounding issue depending on the hardware (my version is only slightly older than yours).
OS: macOS 10.16
Version: 0.21.0.32532 (Git)
Hash: 20e44eba50e1365b9e7bb9c5c244afe96a627a28
Locale: C/Default (C)
  * FC_SU
  * DynamicData 2.46.0
  * freecad.gears 1.0.0
  * FeedsAndSpeeds 0.5.0
  * dxf-library
  * fcgear 1.0.0
  * fasteners 0.4.54
  * sheetmetal 0.2.62
  * ExplodedAssembly
  * Curves 0.6.8
akredd
Post by akredd »
Ok, now i know where i have to look for...
Thanks again.
Andreas
