Error when Post Process
BillyWhiz
Post by BillyWhiz »
I have tried creating an .NC file on 3 different computers all have failed with the message "Running the Python command 'Path_Post' failed:"
I have read some forum with the same issue and they resolved by updating their FC, however I have the latest version :(
please help.
Steps taken till error arrives:
1) select job and check model to be processed. check job edit. "error" please see attached error file.
2) select engraving path and add base geometry
3) adjust depths as required
4) run simulation (ok)
5)
Billy
Error.txt
(1.92 KiB) Downloaded 22 times
Re: Error when Post Process
Hi and welcome to the forum!
Please attach your full FreeCAD info as described in the IMPORTANT forum rules.
Add a file and a step by step description what you do.
freman
Post by freman »
You are not accurately reporting all the steps you take. Selecting a job does not present you a chance to check a model.
Please describe carefully what steps you are doing.
Also read the guidlines, you have not posted FC version info.
GeneFC
Post by GeneFC »
freman wrote: Mon Mar 27, 2023 5:42 pm
I think the meaning is "check the box" to select a model, not to somehow examine (check?) the model.
The initial steps look OK, but there is not enough detail or a file to go any further.
Gene
freman
Post by freman »
Agreed. I think he referring to a checkbox but the steps he described means he would not be seeing one. I'm not going to try to double guess what he "really" did. That is why I requested a more accurate account.
BillyWhiz
Post by BillyWhiz »
Thanks Guys for your posts, is there any videos or documentation on the correct steps to take on outputting a NC file? as the simulator works fine :)
The FC version is posted .... and yes I meant selected the check box.
Billy
bmsaus4ax
Post by bmsaus4ax »
BillyWhiz wrote: Mon Mar 27, 2023 9:46 pm Thanks Guys for your posts, is there any videos or documentation on the correct steps to take on outputting a NC file? as the simulator works fine :)
Billy
The best answer to this is to attach your "_____.FCStd* file .
This file will then allow forum members to look into all the common pre-conditions for a successful output.
Tracking some steps through the documentation can be difficult as not every detail or step is necessarily covered in terms that you may be thinking of.
BillyWhiz
Post by BillyWhiz »
Hi There,
Thanks for your help.
Attached is the file :)
Sample.FCStd
(40.7 KiB) Downloaded 20 times
bmsaus4ax
Post by bmsaus4ax »
BillyWhiz wrote: Tue Mar 28, 2023 1:56 am Hi There,
This error situation seems to very specific to the hiedenhain post processor.
( the actual error messages I get vary from posted error.txt file as I am not using Windows version but the failure is consistant )
I can get output from the sample file using a wide variety of other post processors .
I suggest you select another post processor to test.
for example , linuxcnc is a very typically stable one which has versions which work in both pre and post refactor versions. ( versions later than yours require modified post processors, after the code refactor )
I tested on this version. ( pre-refactor )
OS: Ubuntu 20.04.6 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.28993 (Git) AppImage
Branch: (HEAD detached at 6d92e53)
Hash: 6d92e532bcc31c99a0ab4c153ff00b6414b8f527
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
  * fcgear 1.0.0
  * Curves 0.4.4
  * Lithophane
  * CurvedShapes 1.0.3
BillyWhiz
Post by BillyWhiz »
Hi bmsaus4ax,
Yes, it all works with a different post processor :)
Thank you guys for your kind help....
regards,
BillyWhiz
