Attaching Parts along single axis
Vagulus
Post by Vagulus »
Version: 0.20.1.29410 (Git)
Branch: releases/FreeCAD-0-20
Locale: English/New Zealand (en_NZ)
  * Assembly4 0.12.5
  * BOLTSFC
  * Curves 0.5.1
  * dodo
  * fasteners 0.3.46
  * parts_library
Using Assembly 4
I want to assemble these two parts so that the Palliasse fits into the Wardrobe along the Y-Axis as shown:
230326 Foldaway Assembly.png (3.88 KiB) Viewed 474 times
Trick is, for demonstration purposes I want to incline the Palliasse at, say, 30° from the horizontal. It would be nice if I could vary the angle pretty much at will to show the hinge characteristic.
I haven't yet found a way to do this in FC. Would someone please show me how?
Thanks
Foldaway.FCStd
(31.44 KiB) Downloaded 27 times
"It is much harder to simplify than to complicate."
Joseph Kimble
Jolbas
Re: Attaching Parts along single axis
Post by Jolbas »
Make it an Assembly ("New Model" tool) and add the Wardrobe part. Then add the Palliasse part connected by each Pivot LCS.
Use the Add Variable tool and create a variable named e.g. HingeAngle.
Edit the Angle of AttachmentOffset of the Assembled 'Palliasse001' link in the Assembly.
Set its expression to Variables.HingeAngle
Activate the Animate Assembly tool and choose to animate the HingeAngle variable
Attached a prepared document to try the animation tool on. The Wardrobe part has an added LCS to be able to attach it to a wall and the Pivot LCSs are adjusted to have their Z axis along rotation axis.
Foldaway_Jolbas.FCStd
(37.06 KiB) Downloaded 31 times
Vagulus
Post by Vagulus »
Thanks. You can see the advantage. It shows the interference at the top when the Palliasse enters the wardrobe.
Joseph Kimble
