Unable to engrave an arc
adrianre12
Post by adrianre12 »
I am trying to engrave a simple dial. I have created the dial in the draft bench using an Arc, straight lines and Shapes from text.
When I create a job to engrave it I find that it will engrave the straight lines and the text, but ignores the arc.
I have tried watching videos on engraving but they all seem to either just use text or SVG pictures and I don't understand how to overcome this.
In this example I have only included the arc and two of the lines, you can see the path just engraves the two lines.
Screenshot 2023-03-25 141625.png (108.46 KiB) Viewed 830 times
I am using;
Version: 0.20.2.29603 (Git)
Branch: releases/FreeCAD-0-20
pot-label.zip
(84.5 KiB) Downloaded 16 times
Shalmeneser
Re: Unable to engrave an arc
Post by Shalmeneser »
FCStd file format is already a zip file (you can try to open it like a zip).
Please do not overzipped it.
pot-label.FCStd
(98.06 KiB) Downloaded 13 times
Moved to Path forum.
It works in 0.21. Please retry.
adrianre12
chrisb wrote: Sat Mar 25, 2023 7:03 pm It works in 0.21. Please retry.
Hi, thanks for the reply, it seems I have more problems with 0.21
I uninstalled 0.20 and ran the 0.21 installer. When loading my drawing I got a lot of errors. I downloaded the latest build and extracted it into the 0.21 install dir. I still get a lot of errors.
I also tried resetting all my user prefs too.
10:18:43  Traceback (most recent call last):
  File "F:\FreeCAD 0.21\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\feature.py", line 139, in _import
  File "F:\FreeCAD 0.21\Mod\Draft\draftobjects\wire.py", line 34, in <module>
    import DraftGeomUtils
  File "F:\FreeCAD 0.21\Mod\Draft\DraftGeomUtils.py", line 68, in <module>
    from draftgeoutils.geometry import (findPerpendicular,
  File "F:\FreeCAD 0.21\Mod\Draft\draftgeoutils\geometry.py", line 35, in <module>
    import draftutils.gui_utils as gui_utils
  File "F:\FreeCAD 0.21\Mod\Draft\draftutils\gui_utils.py", line 50, in <module>
    from pivy import coin
  File "F:\FreeCAD 0.21\bin\lib\site-packages\pivy\__init__.py", line 30, in <module>
    from .coin import SoDB, SoNodeKit, SoInteraction
  File "F:\FreeCAD 0.21\bin\lib\site-packages\pivy\coin.py", line 18, in <module>
    from . import _coin
<class 'ImportError'>: DLL load failed while importing _coin: The specified procedure could not be found.
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathJob'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathSetupSheet'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathStock'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolBit'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolController'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathEngrave'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolControllerGui'
  File "F:\FreeCAD 0.21\Mod\Draft\draftviewproviders\view_wire.py", line 34, in <module>
    import pivy.coin as coin
    from . import _coin
    from . import _coin
  File "F:\FreeCAD 0.21\Mod\Draft\draftviewproviders\view_base.py", line 39, in <module>
    from . import _coin
  File "F:\FreeCAD 0.21\Mod\Draft\draftviewproviders\view_shapestring.py", line 28, in <module>
    from draftviewproviders.view_base import ViewProviderDraft
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathIconViewProvider'
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
    from . import _coin
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathOpGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathJobGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathToolBitGui'
<class 'ModuleNotFoundError'>: No module named 'PathScripts.PathSetupSheetGui'
adrianre12 wrote: Sun Mar 26, 2023 9:36 am I uninstalled 0.20 and ran the 0.21 installer. When loading my drawing I got a lot of errors. I downloaded the latest build and extracted it into the 0.21 install dir. I still get a lot of errors.
I don't have a Windows system, but this sounds as if you have messed things up. To my knowledge, there is no 0.21 installer yet. You get a 7zip file and just unpack it into a plain vanilla empty naked directory. There is in the bin directory the FreeCAD executable.
Before working on an old file containing a Path job, you have to migrate the file, see the first sticky post in the Path subforum.
Please edit your post above and put the code in code tags using the button </>. That makes the post easier to read and shows immediately if there are indentations or not.
adrianre12
chrisb wrote: Sun Mar 26, 2023 12:03 pm I don't have a Windows system, but this sounds as if you have messed things up. To my knowledge, there is no 0.21 installer yet. You get a 7zip file and just unpack it into a plain vanilla empty naked directory. There is in the bin directory the FreeCAD executable.
I have removed and reinstalled FreeCad just by extracting the latest 7zip file.
I ran the script from the sticky post and now the updated FCstd will load.
I still can not get it to show a path for the arc, I have even tried removing the whole job and recreating it, but I still only get the two lines.
I have attached the version that has been run through the migration script and where I have deleted and recreated the job.
Version: 0.21.0.32457 (Git)
Hash: 85216bd12730bbc4c3cbf8f0bc50416ab1556cbb
Python 3.8.16, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
pot-label_current-new.FCStd
(97.68 KiB) Downloaded 13 times
adrianre12 wrote: Sun Mar 26, 2023 3:22 pm I have removed and reinstalled FreeCad just by extracting the latest 7zip file.
Please attach your full FreeCAD infos, for now and especially for future readers.
You have to add the arc to the BaseGeometry. This seems a bug for which you should create an issue on Github - if if others such as @GeneFC don't object.
GeneFC
Post by GeneFC »
chrisb wrote: Sun Mar 26, 2023 4:31 pm You have to add the arc to the BaseGeometry. This seems a bug for which you should create an issue on Github - if if others such as @GeneFC don't object.
@adrianre12
I don't know any reason I would object. 8-)
I think this is a user problem however. When I selected all the elements in the model tree as part of the Job setup (General tab) everything seemed to work fine.
The original had a very limited selection and did not include any solids. I have never used Engrave, but it seems to work better when it has something to cut, not just a 2D pattern.
Gene
