3D surface hangs when choosing the "Spiral" cut pattern.
Anon
Post by Anon »
when I try to run the "Spiral" cut pattern on this test file it just consumes 100% of 1 CPU core. After like 16 hours I terminated the process. Could someone please check if this is reproducible?
opencamlib-git from AUR
2023.01.11.6.g7149b04
freecad-git from AUR
OS: Arch Linux (GNOME/gnome)
Version: 0.21.0.32468 (Git)
Build type: None
Hash: 30e815a69d339421367ad7b5ef0391833ba8e497
Python 3.10.10, Qt 5.15.8, Coin 4.0.1, Vtk 9.2.6, OCC 7.6.3
  * fasteners 0.4.55
Maybe I'm just missing something and Spiral shouldn't work anyway.
test.FCStd
(442.26 KiB) Downloaded 24 times
xemul
Re: 3D surface hangs when choosing the "Spiral" cut pattern.
Post by xemul »
It work (with some glitches on trajectory). You can try with your model scaled down by 100 or by 10.
(You miss settings for TC's movement speeds and for rapid movement speeds in SetupSheet)
(StepDown = ToolDiameter and single pass usually suitable for foam or for air cutting; StepOver = ToolDiameter for ball end? why not when you know what you doing)
Russ4262
Post by Russ4262 »
Anon wrote: Sat Mar 25, 2023 12:18 pm Hi,
when I try to run the "Spiral" cut pattern on this test file it just consumes 100% of 1 CPU core. After like 16 hours I terminated the process. Could someone please check if this is reproducible? ...
As stated by xemul, it works. Source file is attached. The Spiral cut pattern is more computationally intensive than most of the other patterns. This, in combination with the size of the work piece and other characteristics of the Surface op increase the computational time very much.
Russell
Version: 0.21.0.32532 (Git)
Hash: 20e44eba50e1365b9e7bb9c5c244afe96a627a28
  * FC_SU
  * freecad.gears 1.0.0
  * PathExp
  * Z_MacroStartup
Snip macro screenshot-367f6b.png (104.95 KiB) Viewed 445 times
test - Copy.FCStd
Source file for attached screenshot. Surface op with Spiral cut pattern.
(154.89 KiB) Downloaded 14 times
