A simple sketcher problem [ solved ]
tonyaimer
Post by tonyaimer »
Hi all - first the mandatory information
OS: Linux Mint 20 (X-Cinnamon/cinnamon)
Version: 0.21.0.31850 (Git) AppImage
Hash: d8d3bb8120ad139cf1eb2acf0be0ae6c297ac7f3
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: English/South Africa (en_ZA)
  * Help 1.0.3
I am doing something very wrong.
I made a simple sketch on the XY plane - a square 50mmx50mm.
I then padded it out in Z to a height of 50mm
I then selected the top face to place a rectangular array of 4 bolt holes.
I know that this is not recommended due to TNP but I figured that these are the last features to be added on the real model
so perhaps it wont matter.
I constrained the first hole and double clicked on that sketch in the model.
The rectangular array tool is greyed out so I am doing something wrong.
The rectangular array tool has the following instructions ( extract ).
Usage
Select sketcher elements in task panel or in 3D view.
There are several ways to invoke the command:
Press the Sketcher RectangularArray Rectangular array button.
Select the Sketch → Sketcher tools → Sketcher RectangularArray Rectangular array option from the menu.
But the tool is greyed out
I am doing this on a 50 cube as a test before working on the real model.
I have included the file for reference
junktest1.FCStd
(10.64 KiB) Downloaded 13 times
What am I doing wrong?
Grub
Re: A simple sketcher problem
Post by Grub »
tonyaimer wrote: Sat Mar 25, 2023 10:15 am ...
Usage
Why "double cliked on the sketch ? Just select it (simple click) and the command Rectangular Array should be active
Bance
Post by Bance »
It is not advised to make the array in sketcher, but rather in the solid using multitransform.
If you really want to use the Sketcher's array (see Bance's comment), you have to select the geometric elements before invoking the command.
tonyaimer
Re: A simple sketcher problem [ solved ]
Post by tonyaimer »
Thanks for the replies
I took the advice of working in part design with padded holes and mirror/ polar pattern
The file is just a bit too big to attach to this post
It is a crankcase for a model engine ( firefly )
Now I need to make in aluminium for real
Tony
