freecad-master-build/Mod/Path/Path ?
freman
Post by freman »
I'm trying to test some changes but I'm not sure about the new file tree in Path. I build recent master pull in freecad-master-build.
What is freecad-master-build/Mod/Path/Path about , is this still half migrated to a new layout?
I wanted to make changes to freecad-build-master/Mod/Path/PathScripts but changes to not seem to be read. Even deleting PathDrilling.py did not produce an error when processing a drilling path.
Do I need to get rid of pycache somehow, or edit the main tree and let make copy it all across ?
Is there some documentation of the new code structure? It seems this file is not even used now.
Thanks for any tips/explanations.
TIA.
openBrain
Re: freecad-master-build/Mod/Path/Path ?
Post by openBrain »
Looks like you're modifying files in the build folder rather than in the source folder ...
freman
Post by freman »
Indeed. That way I just need to close FC and restart it to get my new py file read in, instead of running make as well. I don't want to do that for every dot and comma stupid tab syntax change.
Once I have it running I will obviously want this as a local mod in the source tree.
This used to work but I suspect files have moved and I'm not editing the right thing.
freman
Post by freman »
Ah looks like the drilling file is now at : FreeCAD/src/Mod/Path/Path/Op/Drilling.py
