Unable to install FCGear in FreeCAD v0.19
Nick_Ray
Post by Nick_Ray »
In Windows 10, FreeCAD V0.19 :
This package is not coming up in Addon Manager External Workbenches list of packages available to install....
I tried to install using pip in Windows 10, the folders shown below got created in site packages.. but the workbench did not show up in the FreeCAD upon start...
freecad
freecad.gears.0.0.4-py-3.9.egg-info
numpy
numpy-1.24.2.dist-info
pip
pygears
I removed and installed them to the user/roaming/freecad/mod folder where all the other external workbenches are installed. Again the same folders got created with python code in them but still it did not show up in FreeCAD upon start...
What is the correct way to install it in Windows10, FreeCAD V0.19?
Re: Unable to install FCGear in FreeCAD v0.19
Nick_Ray wrote: Sat Mar 25, 2023 6:31 am I removed and installed them to the user/roaming/freecad/mod folder where all the other external workbenches are installed. Again the same folders got created with python code in them but still it did not show up in FreeCAD upon start...
That would be the right place. Do you see any messages on startup? 0.19 is rather old, so it could even be possible that it will not work at all. Can't you upgrade?
michaelryangreer
Post by michaelryangreer »
Just in case anyone sees this in the future, this package is listed as "freecad.gears" in the package manager, not "FCGear". Installation worked fine for me on Ubuntu 22.04LTS.
michaelryangreer wrote: Tue May 02, 2023 1:40 am Just in case anyone sees this in the future, this package is listed as "freecad.gears" in the package manager, not "FCGear".
Please note that thi topic is about the ancient FreeCAD 0.19.
