Hello FC,
In regards to the Beso Macro,
I find myself having to choose macro's location over and over again. The system & User Macros have separate file locations correct & will that overcome this?
I find Beso is best if you start the analysis with a fresh master file every time also a little inefficient.
In the attached file a simply supported I-Beam, the strong spots where Beso has removed material could support load as this would be the best location. Which led to wondering is there a way to measure INP file or mesh in general. The only work around I can think of is superimposing geometry over the mesh, & then measuring. However perhaps not the best method for high tolerance.
Beso Macro V's System Macros? / Measure
- Screenshot_Beso_FC_Measure.png (269.55 KiB) Viewed 303 times
