Is there any possibility, to force the feed of way back in zigzag mode?
For example, I can set feed to 60%. But then, How does Freecad calculate the feed size for the zig zag return path? Because, sometimes (in 3D-surface with rotation axis), the feed is much bigger than the tool diameter, so there will be some raw path.
In general it works perfect. But i have to postprocess the generated gcode. Can I handle this by a post-process script within freecad?
Kind regards and thanks.
3D surface zigzag force size of return feed
Re: 3D surface zigzag force size of return feed
I don’t think that this can be done in the postprocessor, because there is all information lost of what a return path is.
