[addon] unit tests fail in master
uwestoehr
Post by uwestoehr »
@chennes , I discovered today failing unit tests with the Addon manager:
- open FC and switch to the Test framework WB
- there run the test "TestAddonManagerApp"
result: everything is OK
- re-run the same test
result: you get 5 failures
I think the tests should always pass, no matter how often they are run, right?
chennes
Re: [addon] unit tests fail in master
Post by chennes »
Yes, definitely. I thought I had cleaned all of that up (when I was first learning to write the tests I had lots of unintended side effects!), but apparently not. I'll give it a look this weekend.
Chris Hennes
Pioneer Library System
saso
Post by saso »
Why is there no Test Wb in daily windows builds :|
uwestoehr
Post by uwestoehr »
saso wrote: Fri Mar 24, 2023 11:44 pm Why is there no Test Wb in daily windows builds :|
In the weeklys I provide there is test WB. Do the Conda builds don't have them or what is the build where this is not available?
saso
Post by saso »
uwestoehr wrote: Sat Mar 25, 2023 11:42 am
Yes both FreeCAD_weekly-builds-32457-2023-03-23-conda-Windows-x86_64-py38.7z and ...-py310.7z don't have it
chennes
Post by chennes »
I think those intermittent failures are because I'm not waiting long enough for the dialog to open: the goal is to keep each test under 0.1s (per Feathers' advice in Legacy Code), and that's probably not long enough in some cases. For those I'm going to try just adding a bit longer wait before deciding the test has failed. (That failure isn't related to the one Uwe pointed out above).
Chris Hennes
chennes
Post by chennes »
@uwestoehr this PR should fix the issue you report: https://github.com/FreeCAD/FreeCAD/pull/9047
Chris Hennes
uwestoehr
Post by uwestoehr »
chennes wrote: Sat Mar 25, 2023 3:40 pm @uwestoehr this PR should fix the issue you report: https://github.com/FreeCAD/FreeCAD/pull/9047
Many thanks. Confirmed fixed.
uwestoehr
Post by uwestoehr »
saso wrote: Sat Mar 25, 2023 1:01 pm Yes both FreeCAD_weekly-builds-32457-2023-03-23-conda-Windows-x86_64-py38.7z and ...-py310.7z don't have it
Can you therefore please open a new thread and inform looo about this that he can have a look?
