How to disable Drag-And-Drop for a 'Part::FeaturePython' object?
galou_breizh
Post by galou_breizh »
For context, I'm trying to disable drag-and-drop for an object of type Part::FeaturePython in joint.py.
Thanks,
Gaël
Re: How to disable Drag-And-Drop for a 'Part::FeaturePython' object?
Do you want to avoid that an object can be dragged, i.e. moved to a container object or avoid that other objects can be dropped on it?
galou_breizh
I want to disable that another object is dropped on my custom object derived from Part::FeaturePython.
galou_breizh
@wmayer
Roy_043
Post by Roy_043 »
Create a canDropObject function in the view provider class that always returns False.
    def canDropObject(self, obj):
        return False
See for example:
https://github.com/FreeCAD/FreeCAD/blob ... w_layer.py
