Image Workbench is missing on the latest Weekly.
Re: Image Workbench is missing on the latest Weekly.
@Syres
I can no longer import an image. File/Import
How should it be done?
Thank you for your help
Which build revision are you using, I've looked through the whole thread and can't even tell which OS you're using, it's important as things are changing by the day if not the hour?
The Windows LibPack build revision 31552 is the most recent available on the Weekly bundles and that I believe will present a dialog box after you've done File>Import>selected image file asking for FreeCAD Image or Image Standard choose FreeCAD Image radio button and click OK. All my tests have been using known good png files to eliminate any image files that could give trouble. Using the build below, it just creates a plane without the dialog box.
Version: 0.21.0.32592 (Git)
Hash: 548f9ce07286e40735159e6ece603704c5386f1c
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.3.0
* Silk 1.0.0
* A2plus 0.4.60k
* CurvedShapes 1.0.4
* MakerWorkbench 1.0.1
* freecad.gears 1.0.0
* Curves 0.6.8
* PieMenu 1.2.4
* toSketch 1.0.1
* Plot 2022.4.17
* AirPlaneDesign 0.4.0
* fasteners 0.4.54
* sheetmetal 0.2.62
Core: support to load old project files containing image planes
Hi @Werner,
I tried the:
Version: 0.21.0.32568 (Git)
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.2
could it be possible to fix also this?
I'm attaching a sample file: the right scale for the plane is:
7.03mm
8.70mm
Image-Plane Placement seems correctly restored, and so transparency attribute.
@Syres
I'm confused
I'm confused
OS: Windows 11 Version 2009
Version: 0.21.0.32457 (Git)
Hash: 85216bd12730bbc4c3cbf8f0bc50416ab1556cbb
Python 3.10.9, Qt 5.15.8, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Locale: French/France (fr_FR)
@easyw-fc
after downloading your file, I do not have the image in the tree structure
- Capture d'écran 2023-03-28 100352.png (10.53 KiB) Viewed 1444 times
Sorry I now realise I should have stated git revision 32552 in my previous note, just navigate to https://github.com/FreeCAD/FreeCAD-Bund ... kly-builds and please download FreeCAD-0.21.0dev-32552-Installer.exeBernard19 wrote: ↑Tue Mar 28, 2023 7:59 am @Syres
I'm confusedCode: Select all
OS: Windows 11 Version 2009 Version: 0.21.0.32457 (Git)
It's a proper installation of the Windows LibPack build (your's looks like a few days old Conda build) and then you can at least work with a version that I can replicate any issues side-by-side.
@Syres
With this Fc version, and your macro I found the possibility of importing an image as a layer and of affixing a scale.
I hope that we will quickly find the Image workbench.
Thanks for your alternate solution.
Version: 0.21.0.32552 (Git)
Hash: e2b3a5d2f791fb78a61daac9bdab374058f682f2
