Image Workbench is missing on the latest Weekly.
LHC
Re: Image Workbench is missing on the latest Weekly.
Post by LHC »
Yes sir. I just downloaded the windows conda weekly and tried this out again. Flows smooth enough and didn't delete my image plane folder from an older model file. I can proceed to explore the new features that have been added now. Thanks !
Looks like the old way of pick a couple of points on the image and specify a distance is not implemented yet. Perhaps if I have to scale something that way, I can use an older version and then proceed with the latest weekly until it's implemented.
Nice to see the rapid releases of FC lately - even if there are a few bumps along the way 8-)
Cheers,
Lewis
drmacro
Post by drmacro »
I just updated the the appimage on one f my machines.
Is this "select points to scale" supposed to be there?
If yes, where/how does one trigger it?
Revision number 32637 (GIT)
Revision date 3/29/23 19:04:57
easyw-fc
Post by easyw-fc »
drmacro wrote: Thu Mar 30, 2023 3:35 pm I just updated the the appimage on one f my machines.
easyw-fc wrote: Thu Mar 30, 2023 9:27 am
very nice, it seems to work very well and user friendly.
I had to build myself...
PR is still not merged ATM
drmacro
Post by drmacro »
I just built it on another machine. When I File>Import and image I get this. There appears to be no tool for selecting scale points, and it isn't in the document.
OS: Debian GNU/Linux 11 (bullseye) (XFCE/xfce)
Version: 0.21.0.32637 (Git)
Hash: 7fa7cb7f0b222864be7416c683166876eab190bc
Python 3.9.2, Qt 5.15.2, Coin 4.0.0, Vtk 7.1.1, OCC 7.5.1
  * MnesarcoUtils 0.2.1
  * ZolkoBase 0.0.1
  * lattice2 1.0.0
  * Curves 0.6.8
  * Nodes 0.1.36
  * QuickMeasure 2022.10.28
  * Manipulator 1.5.0
  * Assembly4 0.12.6
  * freecad.gears 1.0.0
  * sheetmetal 0.2.63
  * Silk 1.0.0
  * kicadStepUpMod 10.17.6
  * A2plus 0.4.60k
  * DynamicData 2.46.0
  * fasteners 0.4.56
  * ExtremeProDark 2.7.8
  * Defeaturing 1.2.0
  * CurvedShapes 1.0.4
onekk wrote: Wed Mar 29, 2023 5:45 pm
chennes wrote: Wed Mar 29, 2023 7:46 pm
+1000
some of the complaints here sound very entitled, image WB functionality is not going away it's just being reworked. Here's how this sounds: "how dare you present me with a small inconvenience for a short period of time just to facilitate the work you are doing as volunteers"
The maintainers are truly evil aren't they?
Are you missing something from image wb? Go talk on the issue about it, ask for what you need and explain why but have some patience for gods sake. I guess I should have left the weekly builds broken for some more time to keep these complainers happy :?
easyw-fc
Post by easyw-fc »
drmacro wrote: Thu Mar 30, 2023 3:49 pm I just built it on another machine.
but did you get the PR files? (PR is still NOT merger atm)
the task menu has interactive button...
drmacro
Post by drmacro »
easyw-fc wrote: Thu Mar 30, 2023 4:34 pm
I'm seeing very weird issues. Two different Debian 11 fresh builds.
  • File>Import list two entries for the Image format (on both PC's)
  • Select one of the entries and it loads the image, but
  • on one PC, jpg comes up in a separate document, png is loaded into the current doc and on the XY plane
  • on the other PC, any image comes up in a new document.
  • If I select the other Image format line in the File>Import dialog, select a file, FC crashes
Right click on the image that is in the document in the tree, select Change and there is no Interactive:
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
  * parts_library
  * kicadStepUpMod 10.16.8
  * Manipulator 1.4.9
  * PrefExtras
  * MyDefaults 2022.9.15
  * ZolkoBase 0.0.1
  * fasteners 0.4.52
  * Nodes 0.1.36
  * MacMechX 2022.9.15
  * ExtremeProDark 2.6.4
  * fcgear 1.0.0
  * plugins
  * Pyramids-and-Polyhedrons
  * Defeaturing 1.2.0
  * Assembly4 0.12.5
  * MeshRemodel 1.8919.0
  * BaseTest 0.0.1
  * OpticsWorkbench 1.0.9
  * workfeature-macro
  * sheetmetal 0.2.60
  * A2plus 0.4.60h
  * BasicMech 0.0.1
  * Dracula 0.0.2
  * Curves 0.6.5
  * workfeature
  * toSketch 1.0.1
  * lattice2 1.0.0
  * ZolkoBase 0.0.1
  * lattice2 1.0.0
  * Curves 0.6.8
  * Nodes 0.1.36
  * Manipulator 1.5.0
  * Assembly4 0.12.6
  * sheetmetal 0.2.63
  * Silk 1.0.0
  * A2plus 0.4.60k
  * fasteners 0.4.56
  * Defeaturing 1.2.0
Syres
Post by Syres »
drmacro wrote: Thu Mar 30, 2023 4:42 pm I'm seeing very weird issues. Two different Debian 11 fresh builds.
The fact that there's two entries appears to be the crucial part of your issue, are you sure that the build_folder/Mod does not contain an Image folder, I had to manually delete mine yesterday before testing? Otherwise I'm at a loss as to how there's more than one entry.
Version: 0.21.0.32636 (Git)
Hash: 9666aac669fc4d84985554bc7c3c61e3cdc2c7ab
Python 3.8.10, Qt 5.12.8, Coin 4.0.0, Vtk 7.1.1, OCC 7.7.1
  * Silk 1.0.0
  * A2plus 0.4.60k
  * MakerWorkbench 1.0.1
  * Curves 0.6.8
  * PieMenu 1.2.4
  * toSketch 1.0.1
  * Plot 2022.4.17
  * AirPlaneDesign 0.4.0
  * fasteners 0.4.54
  * sheetmetal 0.2.63
drmacro
Post by drmacro »
Syres wrote: Thu Mar 30, 2023 4:54 pm The fact that there's two entries appears to be the crucial part of your issue, are you sure that the build_folder/Mod does not contain an Image folder, I had to manually delete mine yesterday before testing? Otherwise I'm at a loss as to how there's more than one entry.
Ok, that solved the issue of two entries. But still no scale by two points...
Syres
Post by Syres »
drmacro wrote: Thu Mar 30, 2023 5:05 pm Ok, that solved the issue of two entries. But still no scale by two points...
Nope, for now you have to use my macro on page 4 of this thread, it's not been merged as easyw-fc stated.
