Licensing
easyw-fc
Re: The need for a default assembly workbench
Post by easyw-fc »
user1234 wrote: Thu Mar 23, 2023 9:57 pm
easyw-fc wrote: Thu Mar 23, 2023 9:52 pm But I said that FC could be bundled as GPL3 with the A3WB and solver, as LinkBranch...
And again, not allowed.
easyw-fc wrote: Thu Mar 23, 2023 9:52 pm And if FC community would like to keep LGPL
Must, beacuse it uses OCCT.
Greetings
user1234
It doesn't seem to me.
KiCAD uses OCCT and it is GPL3
https://www.kicad.org/about/licenses/
user1234 wrote: Thu Mar 23, 2023 9:57 pm Must, beacuse it uses OCCT.
that is not the reason, you can perfectly make GPL software based on LGPL software, it's the other way around that is not allowed.
easyw-fc
Post by easyw-fc »
adrianinsaval wrote: Thu Mar 23, 2023 10:06 pm
Exactly :D
user1234
Post by user1234 »
OK, thanks.
Anyway, FreeCAD is LGPLv2 and can not use GPLv3.
Greetings
user1234
easyw-fc
Post by easyw-fc »
user1234 wrote: Thu Mar 23, 2023 10:11 pm
OK, thanks.
The same for Kicad... KiCAD is GPL3 including OCCT which is LGPL2
so FC could be distributed for users as GPL3 with assembly and solver and as LGPL without.
That is exactly what realthunder is doing without legal issues.
It is possible to ask to KiCAD teams about the legal approach... I know they rely on a legal team for that.
user1234
Post by user1234 »
Same software under two licenses? Seems to me hard to maintain. Besides, many companies still can not use it, since they need LGPL, as jriegel wrote in the linked text above
"FreeCAD is a mixture of a library and an application, so the GPL would be a little bit strong for that. It would prevent writing commercial modules for FreeCAD because it would prevent linking with the FreeCAD base libs."
If a company write a plugin for ERP (example SAP) or for a PDM/PLM (example Siemens TeamCenter), it is still not allowed.
Greetings
user1234
easyw-fc
Post by easyw-fc »
user1234 wrote: Thu Mar 23, 2023 10:32 pm Same software under two licenses? Seems to me hard to maintain. Besides, many companies still can not use it, since they need LGPL, as jriegel wrote in the linked text above
Greetings
user1234
I really doubt a lot to think KiCAD is not spreading around in all the professional world just because its GPL license.
KiCAD doesn't seem to me a failing open source project.
sliptonic
Post by sliptonic »
Let's see what the internet magic wizard says....
easyw-fc
Post by easyw-fc »
sliptonic wrote: Thu Mar 23, 2023 10:47 pm Let's see what the internet magic wizard says....
I would suggest you to be in touch with layers at KiCAD teams .
user1234
Post by user1234 »
easyw-fc wrote: Thu Mar 23, 2023 10:38 pm I really doubt a lot to think KiCAD is not spreading around in all the professional world just because its GPL license.
I can not tell anything about KiCAD (only used it for a private project) or the electric industry, but in the machine engineering when you have an external AUDIT and this is an issue for them, you can (must not) get a really f***ing problem, depends how many time you get to solve it. (To compare, i get a big problem because of a handful old rusty screws, just because they was not on any paper or in the system, the solution was fast, i throw them away. But the whole fun cost us around 2000$/€).
Greetings
user1234
edit: blue
