How to make linear massive without intersection from parameter?
I'm use two metods:
1) create massive PartDesign - LinearPattern
This doesn't fit becouse not create not intersection massive
2) create massive Draft - OrthogonalArray
This doesn't fit becouse not use parametric function
Linear massive without intersection from parameter?
Re: Linear massive without intersection from parameter?
Don't know what a massive is, sorry.
Perhaps try a tutorial;-
https://wiki.freecad.org/Creating_a_sim ... PartDesign
Hello dima8101, greetings to the Community!
I don't understand your request, moreover you should attach at least one file to check, and importantly you should enter the data relating to your system and the version of FC you are using, as specified in the regulation.
The attached file contains two ways of creating Arrays, the first created with the "Part Design" tools (plates in view) the second with the "Draft" tools (subtracted plates).
- Array.FCStd
- (33.26 KiB) Downloaded 7 times
- Array.png (145.56 KiB) Viewed 491 times
I can't set an array of bodies if there is a distance between the bodies. I need a parametric distance setting.
I did it through the menu items: PartDesign - LinearPattern
You need to use an expression. Expressions
The interval can be written as (Occurrences-1) * 50mm (interval in mm) or somesuch.
- Interval.FCStd
- (18.91 KiB) Downloaded 6 times
I formulated the task incorrectly.Bance wrote: ↑Fri Mar 24, 2023 2:27 pm You need to use an expression. Expressions
I don't need a rectangle. Therefore, if you delete it, then the proposed solution does not work.
- 005.png (73.86 KiB) Viewed 351 times
There is a single solid rule for Bodys, that's why it is not possible in PartDesign, you would need a common base (which you could remove later).
In draft you cannot use expressions when using the task panel, but after its reation, you can well use them on the properties.
Attached is a small example of dynamic parameterization (obtained using the "DynamicData" Wb), obviously it can be made more modifiable by adding further parameters and references.
- dynamic_parameterization_with_arrays.FCStd
- (14.33 KiB) Downloaded 8 times
- Dynamic_parameterization_with_arrays.gif (272.64 KiB) Viewed 294 times
