How is this happened? As you can see, the handle of two line are connected together.
I'm new on FreeCAD and please tell me how to solve this problem, thank you very much!
FreeCAD 0.19
Hi guys, I have a boolean cut problem
- Spoon.FCStd
- (307.64 KiB) Downloaded 9 times
- How is this happened.png (163.93 KiB) Viewed 451 times
Re: Hi guys, I have a boolean cut problem
There is no problem. These seams are of a technical nature and are no indication of separate solids. In certain cases (on plane or cylindrical surfaces) they can be removed automatically by setting Refine=true in the last operation. This doesn't work here.
I think OP means this:-
- thomas-neemann
I would create the spoon like this, if you want I can link you to a video about it here
I see. I guess this is a coplanar issue. A clone may not work here, the cut may need a bit of overlap.
Besides: there are links going out of allowed scope and warnings from sketcher (which is no wonder, the sketches are rather messy). Especially the latter could be improved.
Yes, I think I need the video. I think it's very nice to learn different ways to draft.thomas-neemann wrote: ↑Fri Mar 24, 2023 9:01 amI would create the spoon like this, if you want I can link you to a video about it here
thank you!
- thomas-neemann
here it isArthur Harry wrote: ↑Sat Mar 25, 2023 7:27 pm ...
thank you!
https://www.youtube.com/watch?v=gjwRUuDRPGU
