Dimension Reference Error Detection and Correction
aapo
Re: Dimension Reference Error Detection and Correction
Post by aapo »
wandererfan wrote: Sat Mar 25, 2023 8:30 pm The error detection and correction algo works for 3d dimensions also. It doesn't know about projection or hidden lines. It just compares the current referenced shape with the saved copy.
But doesn't the axonometric system depend on the 3D model for the correct distances? If the 3D model changes, the edge numbering in the 3D model may change, too. Or did I understand wrong how the 3D length information is transferred to the axonometric dimensions?
domad
Post by domad »
wandererfan wrote: Sat Mar 25, 2023 8:25 pm
I broke the 3d dims. :oops: https://github.com/FreeCAD/FreeCAD/pull/9053 should put things back together.
git commit 20e44eba50 should fix the problem with 3d dims.
Greetings to the Community!
@wandererfan, I had no doubt you'd fix it in the blink of an eye, thanks!! :D
wandererfan
Post by wandererfan »
aapo wrote: Sat Mar 25, 2023 11:39 pm But doesn't the axonometric system depend on the 3D model for the correct distances? If the 3D model changes, the edge numbering in the 3D model may change, too. Or did I understand wrong how the 3D length information is transferred to the axonometric dimensions?
Edge numbers changing in 3d is handled the same way as edge numbers changing in 2d.
We compare the saved geometry for a dimension with the current geometry pointed to by the reference. If they are different, we search for a good match to the saved geometry. In the 2d case we search the lines on the drawing. In the 3d case we search the model.
Prior to this issue #7830 being resolved, it was necessary to connect the 3d reference geometry to the corresponding 2d geometry using LinkDimension. Now, the 3d reference geometry is projected directly onto the view. This eliminates one source of mismatches.
aapo
Post by aapo »
wandererfan wrote: Sun Mar 26, 2023 2:34 pm Prior to this issue #7830 being resolved, it was necessary to connect the 3d reference geometry to the corresponding 2d geometry using LinkDimension. Now, the 3d reference geometry is projected directly onto the view. This eliminates one source of mismatches.
Ah, I see, so there's already a new independent mechanism to find the 3D references without the LinkDimension mechanism. The development goes forward at so fast pace that it's difficult to even follow it! :D
wandererfan
Phase 2 is available here: https://github.com/WandererFan/FreeCAD/ ... toCorrect4
This phase implements "inexact" matching for lines, circles and vertices. The matching algorithm is describing in issue #8878.
Please test if you can.
user1234
Post by user1234 »
wandererfan wrote: Fri Mar 31, 2023 2:12 pm Please test if you can.
Definitely.
Greetings
user1234
user1234
Post by user1234 »
@wandererfan : i found a small issue
When you edit the sketch (Sketch_edit_me) in that way, that the recomputing does not fail, it the dimension Dimension001 does not work. Also while recompiling the message
Dimension001 - no exact match for changed 2d reference: 0
Dimension001 - trying to match changed geometry - stage 2
GG::bestMatchEdges - matching for geometry type: 6 is not implemented yet
does occur. The fillets does work.
PistonRod.FCStd
(68.81 KiB) Downloaded 36 times
Greetings
user1234
wandererfan
user1234 wrote: Fri Mar 31, 2023 8:17 pm GG::bestMatchEdges - matching for geometry type: 6 is not implemented yet
Geometry type 6 is BSpline. I've only got lines and circles implemented so far. Ellipses and Splines are next.
user1234
Post by user1234 »
wandererfan wrote: Sat Apr 01, 2023 12:57 pm Geometry type 6 is BSpline.
Sorry, i did not know, that the HLR give here, on a simple shape like that, a b-spline output. I do not expect for this phase b-spline support.
Greetings
user1234
user1234
Post by user1234 »
@wandererfan : an other testfile with mwe
mwe_FreeCAD_LTNPAutoCorrect4.FCStd
(18.97 KiB) Downloaded 36 times
- open file
- open techdraw to see the one dimension
- mark the body and rote it 90deg in the placement (axis z is already correct)
---> works
- change it back to 0deg
---> works
- open file
- mark the body and rote it 180deg in the placement (axis z is already correct)
---> does not work
---> "works" means it found the former incorrect reference
- open file
- mark the body and rote it 178deg in the placement (axis z is already correct)
---> does not work
---> is correct again
- open file
- mark the body and rote it 175deg in the placement (axis z is already correct)
---> works
---> does not work
the limit of this case is around 174deg, while 174deg does not work anymore
The question is, is it about rotation, is it about length to height ratio, or is it about the same as before, that the HLR craps out again and makes b-splines, but i get all center marks (maybe some does not work, but looks like, because the center is the same). Following massages occur
Dimension - no exact match for changed 2d reference: 0
Dimension - trying to match changed geometry - stage 2
Greetings
user1234
edit: missung parenthesis
