G2 code, in path. Error on machine. 3D pocket.
ModestModest
Post by ModestModest »
Here is shape.
Using old machine CnCut C-3 CNC for stone
I generated code using uncnc
Tool stone tooling tip Diameter 20mm L 20mm
G1 Y-0.632 Z0.000 F72.000
G2 X-9.978 Y-0.511 I0.962 J0.103 F960.000
G1 X-9.972 Y-0.632
G1 Z-1.000 F72.000
G2 X-9.978 Y-0.511 F960.000
G1 X-9.972 Y-0.632
G0 Z5.000
G0 X-9.972
When G2 line with no "I" or "J" machine compiler says missing parameter (example: G2 X-9.978 Y-0.511 F960.000)
And it's says it will take 27 hour to finish job... it's normal or my model preparing are wrong for "3D pocket" ?
Thanks
Error ON G2.jpg (292.29 KiB) Viewed 781 times
File where is issue generated.FCStd
(659.35 KiB) Downloaded 20 times
Test_code.txt
(696.66 KiB) Downloaded 20 times
Re: G2 code, in path. Error on machine. 3D pocket.
Your machine needs obviously a different way of defining arcs. You may look at the philips post processor, it can do different ways of defining circles, and you may adapt your post processor.
ModestModest
Idk how to do it, they do have CnCutCam you can generate Gcode from DFX, is there are library that I can copy and use as post processor for FreeCad ? CNC use Windows XP OS
There is also a dxf postprocessor.
jbraun
Post by jbraun »
The code posted should fail on any control. Without a radius vector the arc is ambiguous.
example: an arc starting at X0 Y1 and ending at X1 Y0
G2 X1 Y0 J-1
or
G2 X1 Y0 I-0.5 J-1.5
both define an arc but not the same arc, it looks like your machine uses the standard G2/G3 definitions and gives the expected error.
That post looks mostly generic but with differences. Like what's the purpose of G71 ?
ModestModest
It's default settings from FreeCad.
So today I have tried to use philips processor. HEre is code and error from machine.
IS there a G code that switch Y and Z, I usually get code where Z are depth but philips processor use Y for depth
P.S. DXF don't even want to work
New Text Document.txt
(584 Bytes) Downloaded 17 times
Crossmid_complex_left.txt
(600.98 KiB) Downloaded 20 times
I rather thought to look at the philips postprocessor and take usable stuff from it to build your own.
If you want to use it anyway, you can edit it and set SWAP_Y_Z=False. This value is now written in brackets in the postprocessor and I don't really understand why, so you may try as mentioned above or use SWAP_Y_Z=(False).
ModestModest
What about feed rate it's swapped somewhere too ?
Edit: Added code that Native CAM App generate
Edit+: I tried write fro swap False, but it's still swap it
Edit++: Doe some issues I installed 2 times freecad so I have edited wrong post processor. Now It's looks okay, and closer to native Gcode
Mattsson.txt
(11.1 KiB) Downloaded 19 times
ModestModest
Btw I needed turn of G2/G3 swap too :lol:
