No sketch projection, but sketch wrap (tongue drum)
Look picture:
Now I'm experimentating with the 'Sketch on Surface' in the curved workbench, but I don't really know whats going on. You have a very little rectangle to draw in.
The shapes should not be projected, but 'shrink' wrapped, 'projection' on surface in the part workbench I can't use. The sketch should be on top and then wrapped down on to the shape. I need it this way, because the length of the shapes are important for the the tone height so they should be consistend. Appreciate any help.
I can draw the base, it's hollow, the thickness command is a bit unpredictable, so I cloned the body, scaled it and subracted it.Now I'm experimentating with the 'Sketch on Surface' in the curved workbench, but I don't really know whats going on. You have a very little rectangle to draw in.
Re: Would this be possible to design with Freecad (tongue drum)
I did not make your exact design but I think this is the method you want to use
- tongdrum.FCStd
- (558.89 KiB) Downloaded 25 times
Thanks you, I will try the pocket function.
I just ran into a video tutorial on sketching on a surface which should help explaining that rectangle you see.Now I'm experimentating with the 'Sketch on Surface' in the curved workbench, but I don't really know whats going on. You have a very little rectangle to draw in.
- papyblaise
mine sugest
Edit same as Willem sorry
- drum PPB.JPG (47.12 KiB) Viewed 864 times
- tongdrum.FCStd
- (1007.12 KiB) Downloaded 12 times
Thank you all, I will have a look in all this.
... using SketchOnSurface in CurvesWB and Array in Sketcher to produce this pattern.
You can scale the Mapped_Sketch rectangle !!
https://en.wikipedia.org/wiki/Steel_tongue_drum
- tongdrum_4.FCStd
- FC.20.1
- (89.76 KiB) Downloaded 14 times
- tongdrum_3.FCStd
- FC.20.1
- (28.82 KiB) Downloaded 13 times
... a variation for generating tongdrum membranes by using the Link tool and scaling -
still not perfect but a possible hint:
- tongdrum_6.FCStd
- FC.20.1
- (201.3 KiB) Downloaded 13 times
- tongdrum_5.FCStd
- FC.20.1
- (121.24 KiB) Downloaded 15 times
This looks als very good, today I have some time to try the different approaches.
- papyblaise
you should change the title in relation to the project so that others have an easier time doing future research
