DXF export creates multiple lines of the same segment
PAS_Drafter
Post by PAS_Drafter »
Version: 0.21.0.31917 (Git)
Hash: 4639283b459f9ff9093e289908cc003db8745b82
Python 3.10.9, Qt 5.15.6, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
  * Assembly4 0.12.5
  * CurvedShapes 1.0.4
  * Curves 0.6.5
  * fasteners 0.4.53
  * sheetmetal 0.2.60
I've simplified a file down to a simple box with holes. I have it orientated on the XY axis I select the Pad and then go to File, Export, Give it a name, and Ok the preferences and it converts a file. I am using the non legacy converter for this.
I load he file in LibreCAD to take a look. At first glance everything looks great.
LibreCAD Original.png (4.11 KiB) Viewed 592 times
However I can select each segment of the polygon and then move it. This GIF shows that process
I can repeat those steps 2 more times before I get to the original segments.
Additionally I find that after I delete all the large segments, I have missed some very small ones that are still duplicated. If they try to run this file in their Plasma table, the torch path ends up duplicating cuts and trying to cut places that already have been cut. Additionally, it treats the insides and outsides of circles differently so they are cut to wide. Needless to say it makes it useless unless I go in and manually clean up the file.
One or two files is manageable. Cleaning up 100s is not.
I can export the file using the Legacy export and I get something different. Instead of each segment being independent, the whole boundary, including the inclusion circles. act as one. If you click anywhere on the boundary, the whole boundary is selected.
I have no idea of what is going on. I thought I followed the correct procedure to make this work, but I must be missing something.
Side_Boom_Lift_Bracket_PAS_Breakaway2.FCStd
(20.03 KiB) Downloaded 8 times
Roy_043
Re: DXF export creates multiple lines of the same segment
Post by Roy_043 »
Confirmed. The non-legacy importer does not project (or merge) the edges of the faces (see image). If you use the legacy exporter the problem does not occur. For the non-legacy exporter you would need to create a 2D projection with Draft_Shape2DView first.
papyblaise
Post by papyblaise »
it is a flow known to DXF, it creates as many lines as it sees edges on a volume
one solution is to export the DXF of the sketch if it contains all the lines
some machines work from STL, that's another track
I don't know laser cuts, I don't know how to make the adjustment so that the ray is on the right side and have a blank of the right dimensions with the ray that cuts the outside outwards, and the inside of a hole inside
Workshop_Notes
Post by Workshop_Notes »
Is it possible to examine (post) the dxf? Is it a 2D dxf with multiple repeated entities all at z=0 or a 3D dxf? I am not sure if you can view it 'from the side' in LibreCAD.
If it is a 3D dxf, it is a poor solution becasue it involves a bit of Python, but you could use the ezdxf library from Python and delete all entities in the file that do not have a Z-coordinate of zero. That would get you a proper, flat, 2D DXF.
It is a bit of work at the beginning, but once done, the process would be the same on every DXF you want to laser.
The suggestion of exporting the sketch as a DXF is probably the most pragmatic.
PAS_Drafter
Workshop_Notes wrote: Thu Mar 23, 2023 9:55 am Is it possible to examine (post) the dxf? Is it a 2D dxf with multiple repeated entities all at z=0 or a 3D dxf? I am not sure if you can view it 'from the side' in LibreCAD.
Here is the DXF export with the "extra" segments.
Working with my Plasma table operator this morning, we have found a way to be successful most of the time. I am now just exporting the sketch if it is a simple part built with one sketch. If it a more complex sketch, I have been using Draft to create a Face Binder of the side I want to export and then export that. It seems to solve the problem of having multiple edges most of the time. I have gone back to the Legacy exporter since it will work no matter what direction the sketch is orientated, as long as I open the sketch first before exporting.
This has worked most of the time, but we still ran into a few pieces where there were gaps in the boundary when it got to the plasma software. In those cases, I had to import the data into a third party software, locate the gaps, fix them, and then export them out again. After doing that, he was able to import the part successfully. NOT an ideal situation, but it at least has us going again.
Right now I have little faith in the non-legacy exporter. The limitation of only exporting from one angle is a killer for me.
BreakawayPad5.dxf
(14.81 KiB) Downloaded 6 times
