[Solved] Is there an easy way to get the length of a b-spline
jfc4120
Post by jfc4120 »
  * Help 1.0.3
I am looking for a way (simply way) to get the length of a b-spline but not using the curves workbench. Any suggestions?
Only post I have seen is viewtopic.php?t=55155
But it just gives 0.00. Okay I tried Macro FCInfo https://wiki.freecad.org/Macro_FCInfo got the length.
edwilliams16
Re: Is there an easy way to get the length of a b-spline
Post by edwilliams16 »
Any edge, b-spline or anything:
Select in the 3D view.
Edit|Send to python console (or ctl-shift-P)
sub.Length in the console.
EDIT
or install @dan-miel 's QuickMeasure tool. It is really handy.
jfc4120
Re: [Solved] Is there an easy way to get the length of a b-spline
Post by jfc4120 »
Got it, select first, rt click, send to python console:
doc.getObject("BSpline002")
>>> shp = obj.Shape
>>> sub = obj.getSubObject("Edge1")
>>> ### End command Std_SendToPythonConsole
>>> sub.Length
396.5090127490411
jfc4120 wrote: Wed Mar 22, 2023 11:35 pm Only post I have seen is viewtopic.php?t=55155
The macro doesn't work reliably while you are in Sketcher's edit mode.
You have to select the spline in 3D view, and not the sketch in the tree.
So yes, there are some restrictions :cry: .
mario52
Post by mario52 »
Hi
example of macro to use in sketcher open : How to select edges inside of Sketcher?
if Gui.ActiveDocument.getInEdit().Object.TypeId == 'Sketcher::SketchObject':
mario
mario52 wrote: Thu Mar 23, 2023 10:28 am
Thanks for this! I have bookmarked your post for reuse when I rework the small macro. I had already tried once to make it skethcer aware and finally decided to go for the non sketcher version.
mario52
Post by mario52 »
Hi
i have include the code in my macro FCInfo (line 2957) and adapted for it
            if (Gui.ActiveDocument.getInEdit() and (sketch.TypeId == "Sketcher::SketchObject")) and ("Constraint" not in subElemName): # sketcher open
the codes worked by chrisb, openBrain, edi, drmacro, abdullah, paullee ... allowed me to give info in a sketcher open and add it to my macro
thanks all
mario
