Need help trying to recreate an old gear
mconsidine
Post by mconsidine »
OS: Linux Mint 21 (X-Cinnamon/cinnamon)
Version: 0.21.0.32435 (Git)
Hash: 48a921d2b73fa6163571a71d7416d60f2bd7c2b2
Python 3.10.6, Qt 5.15.3, Coin 4.0.1, Vtk 9.1.0, OCC 7.6.3
  * toSketch 1.0.1
  * Alternate_OpenSCAD 1.0.0
  * Render 2023.2.2
  * Manipulator 1.5.0
  * Help 1.0.3
  * POV-Ray-Rendering
  * MeshRemodel 1.8919.0
  * freecad.gears 1.0.0
  * fasteners 0.4.55
  * Silk 1.0.0
  * Dracula 0.0.2
  * Curves 0.6.8
  * ThreadProfile 1.84.0
I am trying to recreate an old gear. The actual gear part can be handled by the Gear WB. It's the "interior" part that is challenging me. This gear has six spokes, each of which tapers a bit from the center and whose profile is an ellipse. Right now, I'd just be happy figuring out how to carve out the pie-shaped pieces, leaving the spokes to be dealt with via a fillet.
I've attached what I've got so far, after a few tries. What I'm trying to do is use an imported image as a template for a Sketch. In the sketch I constrained (not fully, I admit) the corners and connections. What I can't seem to figure out how to do is take the intersection of those lines, and extrude them to a solid that I can then multiply 6 times and cut from a disc.
I started using the Part WB and perhaps I should have started with Part Design. That said, can anyone give me some direction on getting the solid I'm looking for?
TIA,
mconsidine
old_gear_test.FCStd
(150.5 KiB) Downloaded 28 times
Bance
Re: Need help trying to recreate an old gear
Post by Bance »
Try a tutorial or two.....
Tutorials
Specifically look at the sketcher tutorials.
Using circles in that fashion will not work, instead use arcs and connect with tangent constraints.
As a follow-up to Bance's recommendations:
1) You can use the trim tool to remove the excesses
2) Either turn the image or just take it for the dimensions, but in any case you should create the cutout symmetric to the Y-axis (or X).
papyblaise
Post by papyblaise »
use the "Fillet" tool of sketcher to make the interior radii
In Part Wb you have to do boolean operations to build a uniform object
gear.FCStd
(553.88 KiB) Downloaded 11 times
mconsidine
Thank you all for the pointers. I had overlooked the Trim function and appreciate the workflow description.
mconsidine
thomas-neemann
Post by thomas-neemann »
mconsidine wrote: Wed Mar 22, 2023 10:23 pm ...
if this is a solution for you, i can link a video to it
old_gear_test-tn.FCStd
(152.97 KiB) Downloaded 12 times
mconsidine
@thomas-neemann A video link would be helpful. Thank you as well.
mconsidine
thomas-neemann
mconsidine wrote: Thu Mar 23, 2023 11:12 am @thomas-neemann A video link would be helpful. Thank you as well.
mconsidine
here it is: viewtopic.php?p=670054#p670054
Shalmeneser
Post by Shalmeneser »
:idea:
Capture d’écran 2023-03-23 122929.jpg (71.13 KiB) Viewed 480 times
(152.97 KiB) Downloaded 10 times
I have rebuilt the model in PartDesign, so you can see the differences, but finally it is a question of your personal preference whether you use Part or PartDesign. I like to take advantage of the simpler tree, because PartDesign always does the booleans automatically. At the same time I have placed the sketch as mentioned above.
There is a good reason why I so strongly recommend to fully constrain your sketches: it can reveal flaws in your design. Here is one:
This should probably be tangent.
By appropriately arranging the features, I do the hole in the middle for all features at once.
If the big subtractive tube should be subtracted on both sides, I would recommend to center the gear, and do a mirror of the pocket.
(Due to the size limit I add only 5 cutouts)
old_gear_cb.FCStd
(998.52 KiB) Downloaded 11 times
