Use a Specific Font
Cuq
Use a Specific Font
Post by Cuq »
I'm need to use a specific font in a workbench. I did not find any example in the existing Workbenchs of declaration or use of a font in a Python code. Would someone have a start of track to integrate this font?
Thanks a lot
Cuq
Re: Use a Specific Font
Moved from Developers forum.
Cuq wrote: Wed Mar 22, 2023 1:22 pm Hello,
Thanks a lot
Cuq
Please explain better, you could not change a font used in UI for a specific WB, they are mostly set using Qt stylesheet, if not you have to make by hand all your WB GUI and assign to each widget a specific font and size.
If you want to use a font for other uses it is another matter.
Roy_043
Post by Roy_043 »
See: viewtopic.php?t=75573&start=30#p657250
fontFile = App.getResourceDir() + "Mod/TechDraw/Resources/fonts/osifont-lgpl3fe.ttf"
fontId = QtGui.QFontDatabase.addApplicationFont(fontFile)
Cuq
Post by Cuq »
Thank you so much @Roy_043 works Like a charm :
    def __init__(self):
        "This function is executed when FreeCAD starts"
        from PySide import QtGui
        fontFile = os.path.join(FreeCAD.getResourceDir(), "Mod", "TechDraw", "Resources", "fonts", "osifont-lgpl3fe.ttf")
        FreeCAD.Console.PrintMessage("{} Added as QtGui Font Id : {}\n".format(fontFile,fontId))
        pass
