Units, Quantities, Schemas and Translations
berniev
Post by berniev »
FYI I have extracted from thousands of lines of code and classes etc the raw data behind units, quantities, schemas and translations. Doing this has made them much more understandable.
Units look like:
//        Angle
//        LuminousIntensity   |
//        AmountOfSubstance   |   |
//        ThermodynamicTemperature   |   |   |
//        ElectricCurrent   |   |   |   |
//        Time    |   |   |   |   |
//        Mass   |   |   |   |   |   |
//        Length   |   |   |   |   |   |   |
//                                                            Name                                       |   |   |   |   |   |   |   |
 * Null type
constexpr UnitSpec uNull                                   { "Null"                                  ,{  0,  0,  0,  0,  0,  0,  0,  0 } };
 * Base SI units
constexpr UnitSpec uLength                                 { "Length"                                ,{  1,  0,  0,  0,  0,  0,  0,  0 } };
constexpr UnitSpec uMass                                   { "Mass"                                  ,{  0,  1,  0,  0,  0,  0,  0,  0 } };
constexpr UnitSpec uTimeSpan                               { "TimeSpan"                              ,{  0,  0,  1,  0,  0,  0,  0,  0 } };
constexpr UnitSpec uElectricCurrent                        { "ElectricCurrent"                       ,{  0,  0,  0,  1,  0,  0,  0,  0 } };
constexpr UnitSpec uTemperature                            { "Temperature"                           ,{  0,  0,  0,  0,  1,  0,  0,  0 } };
constexpr UnitSpec uAmountOfSubstance                      { "AmountOfSubstance"                     ,{  0,  0,  0,  0,  0,  1,  0,  0 } };
constexpr UnitSpec uLuminousIntensity                      { "LuminousIntensity"                     ,{  0,  0,  0,  0,  0,  0,  1,  0 } };
constexpr UnitSpec uAngle                                  { "Angle"                                 ,{  0,  0,  0,  0,  0,  0,  0,  1 } };
 * Other base units are built on combinations of base SI units
constexpr UnitSpec uAcceleration                           { "Acceleration"                          ,{  1,  0, -2,  0,  0,  0,  0,  0 } };
constexpr UnitSpec uArea                                   { "Area"                                  ,{  2,  0,  0,  0,  0,  0,  0,  0 } };
etc.
Quantities:
//                                             Name                   Factor              Unit
constexpr QuantitySpec qNanoMetre           { "NanoMetre"           , 1.0e-6            , uLength                };
constexpr QuantitySpec qMicroMetre          { "MicroMetre"          , 1.0e-3            , uLength                };
constexpr QuantitySpec qMilliMetre          { "MilliMetre"          , 1.0               , uLength                };
constexpr QuantitySpec qCentiMetre          { "CentiMetre"          , 10.0              , uLength                };
constexpr QuantitySpec qDeciMetre           { "DeciMetre"           , 100.0             , uLength                };
constexpr QuantitySpec qMetre               { "Metre"               , 1.0e3             , uLength                };
constexpr QuantitySpec qKiloMetre           { "KiloMetre"           , 1.0e6             , uLength                };
constexpr QuantitySpec qInch                { "Inch"                , 25.4              , uLength                };
constexpr QuantitySpec qFoot                { "Foot"                , 304.8             , uLength                };
constexpr QuantitySpec qThou                { "Thou"                , 0.0254            , uLength                };
constexpr QuantitySpec qYard                { "Yard"                , 914.4             , uLength                };
etc
Schema translations:
//        Scaled Factor
//                                                           Scaled UnitStr         |
//                                                   Scaled LessThan      |         |
//  UnitSpec                              UnitString     Factor    |      |         |
//--------------------- SI1 -------------------------------------------
constexpr UnitTranslations SI1 {{
    { uAngle,                              "°",           1,     {}},
    { uArea,                               "km^2",        1e12,  {{
        { 100,  "mm^2",    1    },
        { 1e6,  "cm^2",    100  },
        { 1e12, "m^2",     1e6  }}}},
    { uDensity,                            "kg/mm^3",     1,     {{
        { 1e-4, "kg/m^3",  1e-9 },
        { 1,    "kg/cm^3", 1e-3 }}}},
    { uForce,                              "MN",          1e9,   {{
        { 1e3,  "mN",      1.0 },
        { 1e6,  "N",       1e3 },
        { 1e9,  "kN",      1e6 }}}},
etc
and schemas:
//                                    Description
//                                Is default    |
//                  Has multiple angles    |    |
//            Has multiple lengths    |    |    |
//             BaseLengthStr     |    |    |    |
//  Name                   |     |    |    |    |                                        Translations
{{ "SI1",                 "mm",  "",  "", "Y", "Standard (mm/kg/s/degree)"            }, SI1                 },
{{ "SI2",                 "mm",  "",  "",  "", "MKS (m/kg/s/degree)"                  }, SI2                 },
{{ "Centimeters",         "cm",  "",  "",  "", "Building Euro (cm/m²/m³)"             }, Centimetre          },
{{ "MmMin",               "mm",  "",  "",  "", "Metric small parts & CNC(mm, mm/min)" }, MmMin               },
{{ "FemMilliMeterNewton", "mm",  "",  "",  "", "FEM (mm, N, s)"                       }, FemMilliMeterNewton },
{{ "Imperial1",           "in",  "",  "",  "", "US customary (in/lb)"                 }, Imperial1           },
{{ "ImperialDecimal",     "in",  "",  "",  "", "Imperial decimal (in/lb)"             }, ImperialDecimal     },
{{ "ImperialBuilding",    "ft", "Y",  "",  "", "Building US (ft-in/sqft/cft)"         }, ImperialBuilding    },
{{ "ImperialCivil",       "ft",  "", "Y",  "", "Imperial for Civil Eng (ft, ft/sec)"  }, ImperialCivil       }
All these things are really just simple data.
berniev
Re: Units, Quantities, Schemas and Translations
Post by berniev »
Unit types
YieldStrength,
YoungsModulus,
UltimateTensileStrength,
ShearModulus,
Stress,
AngleOfFriction,
Magnetization,
VolumetricThermalExpansionCoefficient
are actually aliases of other unit types i.e. they share the exact same structure except for the name (which goes on to be called the type).
I guess this is by design, but it feels wrong?
