adrianinsaval wrote: ↑Thu Mar 23, 2023 9:00 pm
C_h_o_p_i_n wrote: ↑Thu Mar 23, 2023 8:06 pm
That sounds a lot like some religions state ... you shall not x you shall not y ... only the z is the true pure way to go.
No one will force you to change your way, if you're eager to follow your own single solid per body paradigm.
But all other will have the freedom to do it different if they like to.
+1
FREECAD should
not be limiting stuff for the sake of limiting.
+1
Multi-solids should be authorized in PD as an option, as said above. Let users decide the workflow.
A last exemple why single solid paradigm can be so tedious: for welded parts! Welded parts are made of multiples solids, each solid is quite simple.
ATM in PD, you have to create multiples bodies, each on for such simple plate, or gusset, or round bar,.... then use binders to make all of this parametrically... that's crasy.
Hence I design welded parts with Part WB, that's much more straight forward, but use PD WB with multi-solids enabled would be more convenient.
In PD WB with multi-solids paradigm, body container will be to consider as a Part container for PD context.
That's what it is in RT branch.
