A randomly started discussion about the necessity of the PD single solid rule
Locked
FBXL5
Re: #4828 PartDesign: inverse for pocket
Post by FBXL5 »
wsteffe wrote: Tue Mar 21, 2023 8:32 pm What's the problem in a body with more than one solid ?
It is forbidden by the single solid rule now...
wsteffe
Post by wsteffe »
FBXL5 wrote: Tue Mar 21, 2023 9:00 pm t is forbidden by the single solid rule now...
Yes. And it is a pointless rule.
I have split the post as it went totally off topic.
wsteffe
Post by wsteffe »
chrisb wrote: Tue Mar 21, 2023 10:36 pm I have split the post as it went totally off topic.
Good idea. But then let also change the thread title into something like "Allowing more solids in a Body container".
Vincent B
Post by Vincent B »
I can't understand too why a body must have only one part...
if the name "body" not matches very well, just let's change it...
user1234
Post by user1234 »
@FBXL5 or @chrisb : is it possible to rename the first post topic title, that it give a meaningful name? Thanks in advance!
Greetings
user1234
FBXL5 should do it, it's his post.
FBXL5
Re: A randomly started discussion about the necessity of the PD single solid rule
Post by FBXL5 »
I totally forgot that a half sentence of mine started all this. @chrisb split the thread and until his last post I didn't know that I have started this thread. :?
FBXL5 wrote: Thu Mar 23, 2023 7:27 am I totally forgot that a half sentence of mine started all this. @chrisb split the thread and until his last post I didn't know that I have started this thread. :?
Although Adrian started being off topic, you were the first one being completely off.
drmacro
Post by drmacro »
wsteffe wrote: Tue Mar 21, 2023 9:20 pm
Pointless? Someone had a reason, at some point.
And, why is it a problem? It is simple enough to make multiple solids in Part workbench if that it is needed.
A bit of forethought is all it takes to design with the rule.
Locked
