Rule 6 says to use the attachment icon in the text area,but there is no attachment icon. I can capture screens using the Snip tool, but without an attachment icon I can't add them to my post. I Have no problem posting pictures, snips or videos on other boards, just the FreeCAD forum.
When I go to my control panel and click on the manage attachments button, it tells me I have no attachments, but I see no means of adding any from the control panel either.
Help restoring map mode
Re: Help restoring map mode
Thank you all for your patience...I know my designs are simple and basic, but they work for what I am trying to do.
- Pz II Cdr seat back.FCStd
- (136.97 KiB) Downloaded 6 times
- Pz II Cdr Seat bottom.FCStd
- (81.47 KiB) Downloaded 5 times
I checked: it says "Attachment tab", not icon.
Hello!
I may have the exact same problem. I have started a new design, and some of my sketches properties cannot be edited.
Before I forget, I'm using the latest stable version with Ubuntu 23.10.
1. I first made a sketch to describe a part, and could make a pad out of it.
2. I also made another sketch to describe a pocket to the first part. I could make the pocket.
Now I can't change anything to the first sketch properties. I would like to shift it and therefore change the
attachment -> position, but I'm unable to edit it.
I also noticed that the last sketch (not disabled) has a different icon, not sure whether it's linked to this problem, but worth
mentioning.
Here is a picture of the icons. Detail of enabled sketch Picture of disabled sketch. How can I enable the disabled items?
Thanks for any hint.
R
mentioning.
R
The Sketches are not attached, Attach them to enable the attachment section in Properties.
Basic Attachment Tutorial
Icon overlays are described here:-
Tree View
Tree View
Hello!
Thanks for your reply. It works now. Not sure exactly why, but it works.
Regards,
R
Regards,
R
