New Macro " Sketch Constraint From Spreadsheet"
2cv001
Re: New Macro " Sketch Constraint From Spreadsheet"
Post by 2cv001 »
I try with a Link Daily version (with code with accents)
Version: 2023.131.26244 +5365 (Git)
Branch: LinkDaily
Hash: 73c4ca254c5de8849d104973482e98399fb24863
Python version: 3.8.10
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.6.2
Locale: French/France (fr_FR)
And it is OK !!!!
But when I go back to the version 0.21 it does not work
Version: 0.21.0.32258 (Git)
Hash: 0f4acc55beb66dcc9dfab442344c6286d6a2913e
  * Assembly3 0.11.4
  * Curves 0.6.5
  * fasteners 0.4.26
  * Help 1.0.3
  * ThreadProfile 1.84.0
For exemple, if I tried to uninstall the macro I had this message.
It show an issue in filename(s)
Uninstall with daily version is ok.
Macro Sketch Constraint From Spreadsheet :
https://wiki.freecad.org/Macro_Sketch_C ... adsheet/fr
chennes
Post by chennes »
Yes, I'm sorry for the trouble, the fault is mine (and nothing to do with accents or anything like that). I refactored a chunk of the Addon Manager a couple of weeks ago and broke Macro installation. I have not yet had time to track down the source of the error, and it will be at least until the end of the day today before I can begin looking at it.
Chris Hennes
Pioneer Library System
chennes
Post by chennes »
OK, I believe that I have fixed this in https://github.com/FreeCAD/FreeCAD/pull/9018 -- it's been merged, so if you are self-compiled the latest source code should include the fix. Note that you'll have to click the "Update cache" button in the Addon Manager before testing an install.
Chris Hennes
2cv001
Post by 2cv001 »
chennes wrote: Fri Mar 24, 2023 2:52 am - it's been merged, so if you are self-compiled the latest source code should include the fix.
Thanks @chennes!
I do not compile FreeCAD so I will wait for a new version. Do you know when a version pre-compiled will be available ? I don't know the steps between the moment a code is changed and the moment it is operational in the different versions of FreeCAD
It is not a problem for me, to wait. The important thing is that the problem is fixed so that those who want to recover a macro will be able to do so.
Thanks again chennes for your work !
Syres
Post by Syres »
2cv001 wrote: Fri Mar 24, 2023 5:41 am
The AddonManager fix works fine but this has highlighted that the line
 __icon__    = "https://wiki.freecad.org/File:SketchConstraintFromSpreadsheet.svg"
requires changing to :
__icon__    = "https://wiki.freecad.org/Images/1/15/Macro_Sketch_Constraint_From_Spreadsheet.svg"
as at present this is output in the Report View:
09:53:36  Cannot use specified icon for Sketch Constraint From Spreadsheet, https://wiki.freecad.org/File:SketchConstraintFromSpreadsheet.svg is not a direct download link
chennes
Post by chennes »
Yeah, lots of macro authors made that mistake, because on the Wiki itself if you use one of those File: links it will show your image, but that link is really to a wiki page about the image. I actually have code that fixes it when scraping the wiki page for the icon, so I'm surprised that it isn't fixing the link it's getting from the code. I'll take a look.
Chris Hennes
2cv001
Post by 2cv001 »
chennes wrote: Fri Mar 24, 2023 2:26 pm I actually have code that fixes it when scraping the wiki page for the icon, so I'm surprised that it isn't fixing the link it's getting from the code. I'll take a look.
Ok, so for now, i'm not doing the changes Syres suggested to allow you to test. I'll do it later. Is that right?
chennes
Post by chennes »
You can make the changes, that's fine, I'll test it with a unit test.
Chris Hennes
2cv001
Post by 2cv001 »
Syres wrote: Fri Mar 24, 2023 10:04 am
Done.
Thanks !
Edit 25/02/2023
@chennes @Syres
I changed, but at this time, same issue.
So in code, I have now :
__date__    = "2023/03/23"    #YYYY/MM/DD
__version__ = __date__
__Wiki__    = "https://wiki.freecad.org/Macro_sketchConstraintFromSpreadsheet"
and in the wiki, I did the same change :
{{Macro
|Name=Macro Sketch Constraint From Spreadsheet
|Description=Macro which, with a simple click on a spreadsheet cell, adds a length constraint to a line or between 2 points using a spreadsheet cell alias or address (ex. C2). Macro can create alias for you.
|Author=2cv001
|Download=[https://wiki.freecad.org/Images/1/15/Macro_Sketch_Constraint_From_Spreadsheet.svg ToolBar icon]
|Version=00.03
|Date=2023-03-24
|FCVersion=All
Is it ok ?
  * Assembly3 0.11.4
  * Curves 0.6.5
  * fasteners 0.4.26
  * Help 1.0.3
mario52
Post by mario52 »
Hi
i think the problem is after the change freecad to freecadweb
AddonManager search always to freecadweb and the image in to freecad
page web
https://wiki.freecad.org/Macro_crank_simul
icon path
https://wiki.freecad.org/images/0/04/Macro_crank_simul.png
icon searched by AddonManager
15:20:14  Attempting to fetch macro icon from https://www.freecadweb.org/wiki/images/0/04/Macro_crank_simul.png
but certain wiki page hare freecad.org (as my example) other freecadweb.org
mario
